BeastyBlue Posted June 23, 2011 Share Posted June 23, 2011 my '79 mk2 escort doesnt like to start on some cold mornings, is there something i can do to fix this? it has the stock 1300 engine Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 23, 2011 Share Posted June 23, 2011 When was the last time it was properly tuned up? Quote Link to comment Share on other sites More sharing options...
BeastyBlue Posted June 23, 2011 Author Share Posted June 23, 2011 earlier this month Quote Link to comment Share on other sites More sharing options...
coldturkey Posted June 23, 2011 Share Posted June 23, 2011 http://www.nulon.co.nz/products/Start_Ya_Bastard_Instant_Engine_Starter/ Lots of stuff you could do to help, make sure choke is sweet, make sure good spark, make sure timing is set correctly. Also the fuel could be draining out of the carb when it sits for a while and then taking a while to pump back. The latter could be confirmed if it starts easy with some flammable starter spray as above. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 23, 2011 Share Posted June 23, 2011 All good - what did they replace? Quote Link to comment Share on other sites More sharing options...
BeastyBlue Posted June 23, 2011 Author Share Posted June 23, 2011 Just the usual, new spark plugs, new oil, air filter and done the timing Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 23, 2011 Share Posted June 23, 2011 Points and condensor? Was it a workshop or DIY? Quote Link to comment Share on other sites More sharing options...
BeastyBlue Posted June 23, 2011 Author Share Posted June 23, 2011 Yeah a workshop. not 100% sure if they were done, probably were. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 23, 2011 Share Posted June 23, 2011 I would pop back and see them and say that the car is hard starting in the morning and you have just had a tune done. They should be able to buzz over what they did and check it. Most cold starting is a tuning issue.. Quote Link to comment Share on other sites More sharing options...
BeastyBlue Posted June 23, 2011 Author Share Posted June 23, 2011 Alright, sweet as Quote Link to comment Share on other sites More sharing options...
sholdowa Posted June 23, 2011 Share Posted June 23, 2011 Can't remember... is there a 12V supply on crank to an 8V coil with Kent engines? If so, check it's connected and functioning. Quote Link to comment Share on other sites More sharing options...
phr34kr Posted June 23, 2011 Share Posted June 23, 2011 Does it turn over fine? Is your battery in good condition? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted June 23, 2011 Share Posted June 23, 2011 dont mean to hijack the thread here, but when the motos is at top dead center, what postion should the points be in? closed, about to open? open? closing? yes its a 1600 in an escort. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 23, 2011 Share Posted June 23, 2011 should be open - just a tiny amount though and barely visible.. The points just start to open at 5 - 10 degrees before it hits TDC and will be fully open around 50 degrees after TDC Quote Link to comment Share on other sites More sharing options...
Horse25 Posted June 24, 2011 Share Posted June 24, 2011 sweet thank you! will give that a try! Quote Link to comment Share on other sites More sharing options...
eskie77 Posted June 24, 2011 Share Posted June 24, 2011 hey man ,is it a auto choke or a cable operated choke ?if it an auto choke make sure its all adjusted properly.I have a 1600 escort and had major troubles adjusting the chokes till i got it right now it starts first pop took ages too get it right. Quote Link to comment Share on other sites More sharing options...
BeastyBlue Posted June 28, 2011 Author Share Posted June 28, 2011 manual choke. Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted June 29, 2011 Share Posted June 29, 2011 Just stab the throttle twice then hit the key on cold mornings When you wind it over does it slow down as winter kills batteries. I would check the plug gap. How worn is the engine as one of my old girls was a hard starter as it had naf all compression but I couldn't blow it up and I could thrash it all I wanted. It eventually got so low it couldnt start at all. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 29, 2011 Share Posted June 29, 2011 ^ Yeh, try the two stabs on the gas then wind it over. Also, try starting it with no choke, if its starts then your tunes up the fuck. Quote Link to comment Share on other sites More sharing options...
Positive Ape Posted June 29, 2011 Share Posted June 29, 2011 plug gap. Mechanic possibly didn't check the gap when they put the new spark plugs in. Quote Link to comment Share on other sites More sharing options...
