mjrstar Posted October 4, 2023 Share Posted October 4, 2023 1 hour ago, Rhyscar said: That’s a good idea. Doesn’t need to be a full shroud just a piece of decently strong stuff to absorb any impact. Yeah don't make it too heavy, additional weight is the enemy of an n/a racecar. 1 1 Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted October 4, 2023 Author Share Posted October 4, 2023 18 hours ago, shrike said: No plans to convert to electric power steering? Ie from a newer corolla, echo , vitz, prius or GT86/BRZ? Yes but no for a few reasons. I've gone with a MR2 electric PS pump because they've proven to be very reliable in different racecar applications. On-the-column electric powersteer units are good, but are tricky to get feeling right and typically involve welding/replacing the steering column (difficult to get road legal). On the AP4 rally cars they use a Woodward column and mount and have some technical document with LVVTA on how they get them through the cert process. I pretty much wanted to avoid this level of complexity so have stuck with a tried and trusted electric-hydraulic system. 2 Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted November 8, 2023 Author Share Posted November 8, 2023 Little bit of progress over the last little while. Got chassis loom back from Drew and got it fitted to the car. Super happy with the fit up and quality. 4 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted November 8, 2023 Author Popular Post Share Posted November 8, 2023 Bought a cheap dereg shell to steal a windscreen out of it as they don’t make them anymore for these cars. Could of got one custom made but was real spendy. so now I’ve got a windscreen, mirrors, wipers, bonnet pins and all the trim back together, it’s starting to look like a car again! Hoarded heaps of Levin parts from the shell for future Rhys also. this is starting to look great 16 Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted December 8, 2023 Author Share Posted December 8, 2023 Thanks to @Guypie for machining my intake manifold on a 7deg angle. This netted me 16mm of additional bonnet clearance so I'm happy. This should be enough to design some funky-shaped trumpets to fit under the bonnet. Very interesting seeing @kpr testing results, it seems shape doesn't matter too much, as long as length is correct. IIRC 130-160mm trumpet (330-360mm total) is what I was aiming for. Lots of wiring progress lately. A bit more on that soon, but for now here's some satisfying pictures of general tidyness/not being hory. Made a sweet bracket for the speedo sensor pickup off rear hub. This will drive the Monit (for wof purposes), but also allows ECU to do some launch/traction control things (compare front vs rear wheel speed etc) Sweet bracket for clutch and brake pedal switches. Included clutch to do launch control/flat shift at some stage. Lots of holes because aluminum isn't lightweight enough I guess? 9 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted December 8, 2023 Author Popular Post Share Posted December 8, 2023 Loving the slam on this car. Can't wait to slay some backroads in this (at a bit higher height) @vk327 cranking into the wiring. Body loom is 98% complete and working. Very exciting to see lights flashing and wiper going. Starting to feel like a real car, not just a collection of parts thats been sitting in my shed for too long... 15 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted December 8, 2023 Author Popular Post Share Posted December 8, 2023 some more detailed shots of the wiring loom front loom is very tucked up against the bottom rad support. Very minimal most of this area will end up getting covered by a catch can so won’t see most of it. Nice and tidy through the firewall. Tight space so stoked I could make this work. Power steering pump still needs wiring from nearby relay. super happy with how it all fits under the dash Gauge lights all working. All the steering wheel buttons and control panel are working mint. Just another plug needed for the rear part of the loom. This makes me happy. So stoked we wired up the yellow fog lights they look great! 14 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted January 7 Author Popular Post Share Posted January 7 Got radiator side mounts, fans and pipework all sorted over the holidays. These had been holding me up until as their location determines a lot of other engine bay related constraints so was great to get it ticked off. Without a radiator cross-member mounting the top of the radiator was tricky. I ended up welding a boss on each end and finding a shackle bush to mount to the headlight frames. I bloody hope I never bend the front end cause everything will get damaged..... Might need a good crash bar post-cert for bumper-to-bumper racing! Made a shroud for the fans (which are the wrong direction currently due to a brain-fart on my part), mounted 15mm from core so hopefully enough to draw air from whole radiator surface. Have included rivnuts for future addition of bonnet ducting. Now I'm in the process of moving the header tank over to the guard to make the bonnet duct simpler. Should be a great layout when header tank, catch can, rad overflow, bonnet duct and airbox are all finished up. These may take a while to finalise as I'm focusing on jobs that get the car started.. ] This is a HUGE step for me. And super happy with how it worked out. The end is feeling a lot closer and achievable now! Just got to keep moving forward. 17 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted February 17 Author Popular Post Share Posted February 17 Getting a few loose ends of jobs tidied up before I tackle the last big job - extractors. Starting to look like a complete car. Catch can finished up. Internal baffle, tiny K&N filter from a BMW bike, drain tap in bottom so you don’t need to remove to empty!! Fits very well in the allotted space finished up radiator and swirl pot pipework (pending rubber hose) also finally finished the front bumper side ducting (radiator to come but that’s big job/non important to start the thing) Keep moving forward 17 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted February 18 Author Popular Post Share Posted February 18 End of weekend engine bay shot. Made a nifty heat shield for the firewall to keep the important stuff like brake masters and fuel hoses from melting. Rocker cover is off getting a parts wash to get all the swarf out from drilling breather holes out. Sump needs to same treatment after I added an oil temp sensor hole. 10 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted March 7 Author Popular Post Share Posted March 7 Lots of finishing details taking lots of effort with this project. Stuff that's been sitting on the shelf 'finished' for a few years always needs adjustments or I need to remember how it was supposed to be installed... Final adjustments made to the gear shifter. Locked skateboard bearings in place with Loctite (they are a gentle press fit). Also replaced axle seals and got driveshafts in place. Gearbox is ready to roll once I add some oil... Polished up the headlights finally. Look great, but could be better still. Repainted mirrors in repco 'trim black'. Turned out great! Decided to paint gurney flap black as well. Not sold on it but unsure what other options would look any good? Also, its amazing to see how unlike this car looks like a factory Levin... Dropping a car 4" will do that! Pulled the front apart to do final welds on headlight frames. All comes apart in less than 30mins which is great. Wasn't stoked to need to remove radiator again though (it's a bitch of a job!) And because I hate AN fittings & braided hose.... I sourced some Continental heater hose for breathers (not rated for oil but is no pressure and has 150deg C temp rating so should be fine). Bonus that it comes in almost an exact colour match to my car. Still one more hose end to fabricate for the final breather. 2zz has an obscene amount of breather ports so why not use them all!? Less crank pressure = more power. Last night Drew popped around to do a final measure up on engine loom. Added a few things and adjusted the factory loom to suit. He also brought some goodies with him. This is probably the biggest financial piece of the puzzle left so happy to make this step. Assembling the car and touching things up for Toyotafest at Hampton this saturday. Entered show in 'under construction' category. It's bittersweet because it feels good to finally have something worth showing/sharing with people for my 10+yrs of effort, but still so much work in the finishing touches. Next year I'll be driving it!! 17 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted March 7 Author Popular Post Share Posted March 7 Also quite excited about purchasing alternator and water pump undersized pulleys from Monkeywrench racing. Interestingly, they claim a 3-4HP gain on a factory motor, which combined with my lack of belt-driven powersteering, higher compression, ITB's and exhaust could potentially add up to 5-8hp total. Might even get close to K20 power? This few HP is probably the cheapest $$/kw I'll ever make so stoked to have this piece of the puzzle coming together. These are waiting to make it into our suitcases when we visit the states in a few weeks.. 11 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted March 10 Author Popular Post Share Posted March 10 A few snaps from Toyotafest. If anyone got some feel free to share as well. Great to get the car out and chat to lots of people about it. Lots of motivation to finish it now! Trailer queen for first and last time hopefully Finley loved it too 19 Quote Link to comment Share on other sites More sharing options...
Popular Post Rhyscar Posted April 17 Author Popular Post Share Posted April 17 Quick update. Been busy over the past month so this has taken a bit of a backseat. Got some stickers made for steering wheel/dash. Makes it feel a lot more finished. I’m not 100% happy with them yet but they’ll do for now also tidied up the curly cord mounting. Looks legit now. So the set of pulleys I brought back from the states didn’t fit my alternator (which turns out is from a 1zz fielder). So jeffy came to the rescue and made a bush to suit. For future reference..1445mm belt works with no PS, and underdrive alternator and water pump pulleys. This took quite some time to figure out found a wee molded hose to finish up the heater piping. Still need to 3d print an airflow thing for the dash heater ducts. Cooling system is now sealed and ready for a pressure test (pending a few extra hose clamps!) Also replaced gearbox axle seals and filled with oil for first time in 10yrs. Hope not too much damage has been done from sitting around. Bought and sold another Levin to pay for Link Storm g4x and engine wiring loom. Loom worked out great looks very hidden away. Some small mods to make but all simple enough. next up; 1. fix stripped thread in engine mount 2. replace sump with baffled version 3. remount expansion chamber 4. make headers 5. first start?? 17 2 Quote Link to comment Share on other sites More sharing options...
