Vintage Grumble Posted November 24, 2010 Report Share Posted November 24, 2010 Has anyone successfully split a welded 3 piece rim from its center? So that the center/one half rim is still useable? Quote Link to comment Share on other sites More sharing options...
twosmoke Posted November 25, 2010 Report Share Posted November 25, 2010 . Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 25, 2010 Report Share Posted November 25, 2010 Yup, thats how Hugo got his widened by Gavin Quote Link to comment Share on other sites More sharing options...
Simon Posted November 25, 2010 Report Share Posted November 25, 2010 It depends how the wheels are designed. Some you have to completely machine off the front part of the rim, destroying it. Which doesn't really matter if you are going to be getting new bands made. Also for the wheels that come welded, I would advise getting them welded again once you widen them. Those little bolts were never intended to hold the rim together! True 2 or 3 piece wheels will have a lot more bolts holding them together. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted November 25, 2010 Report Share Posted November 25, 2010 The 13x6 A3A's I got fit over my front brakes (only 13's that ever have) so was thinking about widening them. They have a rim half either side of the center, and each half is welded to the center, so two beads of weld. If I can get my hands on the 5th one, I may have a go at machining into the weld and try split the outter half off without eating into the center, should be doable. These places that make the halfs will make up and size rim/PCD you want wont they? Any ideas on how deep the weld would penetrate? Quote Link to comment Share on other sites More sharing options...
Testament Posted November 25, 2010 Report Share Posted November 25, 2010 Welding on top of welds is really shit usually. unless you can machine out all of the heat affected zone it's a bit hmmmm. might be fine but not something to do willy nilly. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 25, 2010 Report Share Posted November 25, 2010 The 13x6 A3A's I got fit over my front brakes (only 13's that ever have) so was thinking about widening them. They have a rim half either side of the center, and each half is welded to the center, so two beads of weld. If I can get my hands on the 5th one, I may have a go at machining into the weld and try split the outter half off without eating into the center, should be doable. These places that make the halfs will make up and size rim/PCD you want wont they?Any ideas on how deep the weld would penetrate? Just send them to gavin and he will remove the weld when he widens them Quote Link to comment Share on other sites More sharing options...
Simon Posted November 25, 2010 Report Share Posted November 25, 2010 Do you know how much he charges? Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 25, 2010 Report Share Posted November 25, 2010 I cant remember exactly but i think it was fuck all really Quote Link to comment Share on other sites More sharing options...
mikuni Posted November 25, 2010 Author Report Share Posted November 25, 2010 Another alternative to rewelding that people can consider, is just putting more bolts in. Generally they use 8 to 10 bolts, so it would be easy to step this up to 16 or 20. I strongly recommend people to talk to Gavin about the size of the centre and whether he can make outer shells to suit before buying or even seperating rims, especially if welded because you may end up with some expensive scrap alloy. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 25, 2010 Report Share Posted November 25, 2010 nope, same guy Quote Link to comment Share on other sites More sharing options...
mikuni Posted November 25, 2010 Author Report Share Posted November 25, 2010 Added phone number to first post, phone 027 246 8948. Quote Link to comment Share on other sites More sharing options...
twosmoke Posted November 26, 2010 Report Share Posted November 26, 2010 . Quote Link to comment Share on other sites More sharing options...
twosmoke Posted November 29, 2010 Report Share Posted November 29, 2010 . Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 29, 2010 Report Share Posted November 29, 2010 Just gave gavin a call, he quoted be fairly different prices to what Mikuni got. - New bands: $190 a wheel - Polishing: $35 a wheel - Machining old bands off: ~$30 a wheel Unsure if he just quotes different prices for different people, or the bands are different or something, but looks like it may cost considerably more than I originally expected. Gavin Bateman came back with a quote of $135+gst* per shell. In additional to this, is the machine polishing fee of $35* per shell. The above price from Batemans is only applicable if you are having 4 shells spun, so a total of $680+gst* to have 4 shells spun to any diameter and any width, within reason. Obviously additional costs include shipping to and from Wellington if you don't live there. * Prices as quoted above are subject to change at any time. The prices are only what I was quoted and should be used as a guideline only. $680 +gst = $782 $190ea x 4 = $760 Seems close enough to me (cheaper even) Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 29, 2010 Report Share Posted November 29, 2010 Brads price seems to include polishing though chris Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 29, 2010 Report Share Posted November 29, 2010 You are right it would appear - I retract my post... Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 29, 2010 Report Share Posted November 29, 2010 Just gave gavin a call, he quoted be fairly different prices to what Mikuni got.- New bands: $190 a wheel - Polishing: $35 a wheel - Machining old bands off: ~$30 a wheel Unsure if he just quotes different prices for different people, or the bands are different or something, but looks like it may cost considerably more than I originally expected. Asked if he can widen SSR Longchamps though, he said no worries done them before. Did you tell him you were getting 4 done? Quote Link to comment Share on other sites More sharing options...
