NYTR1S Posted October 22, 2010 Share Posted October 22, 2010 I have a '83 toyota crown when engine is running the throttle stays open slightly but doesn't when throttle is operated with the engine off. I havnt been able to find any information as to why it does this. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 22, 2010 Share Posted October 22, 2010 Are you sure it's the throttle staying open? What's the problem associated with it being open? Idling too high? The only way it'd be staying open when the car is running would be some sort of vacuum diaphragm pulling it open. Quote Link to comment Share on other sites More sharing options...
Simon Posted October 22, 2010 Share Posted October 22, 2010 My new Corona does this too. If I manually close the throttle in the engine bay it will idle but as soon as I rev it up (from the engine bay) it stays at about 1800. It's not the cable. I have not yet bothered to actually look properly. Quote Link to comment Share on other sites More sharing options...
NYTR1S Posted October 22, 2010 Author Share Posted October 22, 2010 thats what mine does its not tight when i close it by hand but will rev high again if rev it Quote Link to comment Share on other sites More sharing options...
shizzl Posted October 23, 2010 Share Posted October 23, 2010 vac leak??? spray some brake clean around the carby/throttle body/manifold to find leaks.. if it doesnt show anything then you may had a torn/fukt diaphram... Quote Link to comment Share on other sites More sharing options...
NYTR1S Posted October 23, 2010 Author Share Posted October 23, 2010 thanks will try that Quote Link to comment Share on other sites More sharing options...
JoKer Posted October 23, 2010 Share Posted October 23, 2010 bigger return spring... Quote Link to comment Share on other sites More sharing options...
Taistorm Posted October 23, 2010 Share Posted October 23, 2010 Ive got the same problem with my chevette. When i chucked in the 28/36 weber after taking it for a drive the throttle would stick at a rather high rpm. I thought that maybe setting up another cable with a return spring pulling in the opposite direction of the accelerator would solve this or a bigger return spring? havent got around to it though Quote Link to comment Share on other sites More sharing options...
racepics Posted October 27, 2010 Share Posted October 27, 2010 I've seen this happen on older cars when the throttle butterfly spindle is worn (or the carb body or both) - you get a vacuum leak between the spindle and carb body. Quote Link to comment Share on other sites More sharing options...
