oldrx Posted June 10, 2010 Share Posted June 10, 2010 The car has been sitting for a month or so - batt flat. Tried to jump start it today and it will crank for a few seconds before going flat again, this is connected to a known good battery in a running car. If i turn the key again immediately its flat as - just starter motor tick noise. But if i leave it for a few mins still connected to good battery it will crank again for a few seconds and go flat again. WTF?!??!?!? Oh and when i was driving it everyday, sometimes when i turn the key it nothing would happen, second turn it would start fine. This rarely happened though. Wondering if two probs are related? Any ideas?? Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 10, 2010 Share Posted June 10, 2010 Sounds like a fucked battery Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 10, 2010 Share Posted June 10, 2010 Run the POSTIVE jump lead from + on Good Car to + on Flat Car Run the NEGATIVE jump lead from - on Good Car to a solid earth on the Flat Car, NOT TO THE BATTERY. Things like engine lift points and mounts are generally fine, at a pinch, the strut top bolts or the bonnet latch mount. Oh, and the nothing sometimes and perfectly fine the next sounds like an Ignition issue. My C110 used to do it, it was the switch behind the ignition barrel, I replaced it and it was poifekt. Quote Link to comment Share on other sites More sharing options...
oldrx Posted June 10, 2010 Author Share Posted June 10, 2010 Thanks for fast replies! I'll try the solid earth trick a bit later... Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 10, 2010 Share Posted June 10, 2010 Ive had batteries go dead sitting for bugger all, especially if they get completely drained. Also Ive had issues with shit jumper leads, and bad connections to the battery terminals causing similar stuff. Put the battery on a charger over night and see how it behaves after that Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 10, 2010 Share Posted June 10, 2010 It's that time of year too. Cold kills batteries. Which sucks because winter is generally when you need your car the most. Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 10, 2010 Share Posted June 10, 2010 spence mention shit jump leads.. apparently fucked connections can test up fine but turn to shit when you suck big current through them maybe you were getting a bit of a charge from the good battery then immediately draining it and recieving no juice from other battery on cranking but yeah battery/earths/connections will be a good place to start Quote Link to comment Share on other sites More sharing options...
cletus Posted June 10, 2010 Share Posted June 10, 2010 Oh and when i was driving it everyday, sometimes when i turn the key it nothing would happen, second turn it would start fine. This rarely happened though. Any ideas?? a common problem with toyota starters is the contacts in the starter get worn and starter plays up, tis a piece of cake to fix. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted June 10, 2010 Share Posted June 10, 2010 mostly covered by others but what size jumper leads are ya using. if its not ya starter solenoid sounds like the current draws to big for the conductor size. Quote Link to comment Share on other sites More sharing options...
oldrx Posted June 10, 2010 Author Share Posted June 10, 2010 Im starting to think it might be the jumper leads - they're pretty thin shitty ones. I got a good earth in flat car and that gave it a bit more cranking power but still same problem. All connections were cleaned thouroughly before i tried starting it yesterday - they were a bit corroded. Off to buy new leads now... Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 10, 2010 Share Posted June 10, 2010 disconnect the battyer in the dead car, and the good car, and use the jumper leads to connect the good battery to the dead car, if it doesnt start you know its something else. trying to jump through a dead battery is like beating a dead horse... it may be fun to start with but gets old pretty quick. Quote Link to comment Share on other sites More sharing options...
oldrx Posted June 10, 2010 Author Share Posted June 10, 2010 Got new leads and it cranked like a muthafuka and got it started. Thanks for the help would never have thought it might be just the leads! disconnect the battyer in the dead car, and the good car, and use the jumper leads to connect the good battery to the dead car, if it doesnt start you know its something else.trying to jump through a dead battery is like beating a dead horse... it may be fun to start with but gets old pretty quick. Will keep this in mind for future car dramas - i dont know why i bother sometimes. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted June 11, 2010 Share Posted June 11, 2010 good to hear. little leads = little current. if the old ones are copper strip them and take them to the scrappy Quote Link to comment Share on other sites More sharing options...
