Low compression on all cylinders?
Requiemk
75 psi across all 6 cylinders
100 when oil added
I brought head/block a while back acl race rings, bearings etc.
Engine appears to have non turbo pistons, not a major just means a bit more compression a bit less boost. Mint bores, fucked rings. Looked to be apart recently by head to block cleanliness aswell as the condition on triple layer steel headgasket.
Also signs of water going into my oil on small amount of time i ran it, didn't get it hot.
Can excess boost cause all rings to fuck out/any suggestions
  • Replies 42
k disregaurd my other comment i made about fucked rings .
not usually to that extent i dont think.
and 75psi??? , man that not right homie . my ca is 185 across all four ...
your either doing it wrong or got a leak from the compression tester dood
100 when oil added
cam can cause this... the good thing is they are even....
are you sure water is leaking as thats more a worry....
Thats why im stumped eh, had mate around gave me a hand doing it.
I got those dud compression results yesterday with my home made compression tester, assumed it wasn't sealing so grabbed another, same result. Have used this one in past and is trusted.
Engine would start and fire but wouldn't run longer than 20 seconds or so, wasn't keen on reving past medium throttle, likely another issue altogether but worth noting.
you can see the ring just down the side of the piston and notably hear piston moving side to side
woah that a bit of a gap then :S .
Compression was even so i disregarded timing aswell as being spot on when i pulled off the covers.
Water i thought was due to headgasket, radiator pressure tester wouldn't grip onto my radiator cap so couldn't do test without buying a tester to suit.
Signs of clouding in new oil and can see water marks slightly up dipstick, only shown after engine been running.
camshaft timing looked spot on. tdc both cam wheels lined up with markings and cams positioned in right place.
Pistons appear to be stock, bores looked real tidy, no signs of ring wear and can still see honing marks. Appeared to be most of the play in front to back movement, not side to side as where id think it would be due to thrust
You may need to dial the cam in properly... compression isn't an issue and gaps for pistoms not an issue IMO but the leak is the biggest issue, fix that then check compression, is the gasket on the right way? is it the correct one for that model engine?
To give you an idea I run 11:1 compression but only read 125psi on a guage because of my cam and I can see the rings down my bores and run ACL flat tops and filed down rings. The overlap and lobe seperation could be causing the low reading, so now comes the question do you have the specs for the cam as if its a hot cam then it may pay to get it dialed in and I am not sure what a hot cam in a turbo should show as psi.
i lost the guys number a while back with my old phone, not local. Already tried to track down but deadened, cant even remember his name to be honest, have had engine for a good year or so.
Cams appear standard, no cam gears. There was no mention of difference camshafts from seller.
Cams are key wayed onto cambelt pulley and all markings line up so im "assuming" its ok? I haven't played around with cams to much tbh
How can you go past the obvious to me of rings/pistons?
there is some obvious side to side play with audbile noise being made with wriggle side to side comparing this to other engine with same pistons (standard) and same bore size (measured).
measure your bore diameter if your worried about the play in the pistons, Nissan workshop manual i used to build my RB25 says factory sizing is 86-86.030mm, maximum wear should be 0.2mm so your bore shouldn't be anything over 86.2mm or it should have been bored out and using over size pistons.
As for head gaskit as far as i know you can reuse the metal head gaskits (well my old man always has on the avenger) but they always reseal it with some copper head gaskit shit. Could be why your getting water in your oil maybe?
How factory is this thing? can PM you link to Nissan workshop manual if you want all factory clearances (or just google the manual)
haha yeh bloody RB's
id say your piston setup is ok, but like phil said who ran the engine in? could be sealing badly. What do your bores look like? (sounds like you got the head off)
head gaskit seems like a good place to start due to the water in oil problem.
Guy had engine running in his s13 in new plymouth, was tuned/some work done at dobsons.We cant manage to pin point who it was due to my lack of knowledge but at the end of the day it doesn't fix my compression issue....
Head was definitely torqued down, some blow by was apparent through breathers with cranking so going to take engine apart tomorrow night (head off) and check it over.
i tore down an evo engine i was going to tidy up as a spare, brought it as ( rebuilt not long ago but smokes a bit and has low compression readings on all cylinders)
thought it was maybe rings and stem seals
it wasnt, these are where the pistons are now
every ring land on every piston had TWO big ass hairy cracks in it
would be worht checking i suppose if your halfway there just drop on out for a squiz at its crack
