Southern Hardstyle Posted July 22, 2009 Share Posted July 22, 2009 just got a cordia gsr turbo that is a lil dented and is blowing white smoke out the exhaust any ideas on upgrades or places to find other turbos for them? this is the 1.8l soch 4g62 i believe, and cordia nuts know anything about these? mine seems to cut and sputter and 5000rpm in any gear. will post up pics soon Quote Link to comment Share on other sites More sharing options...
Thousand Dollar Supercar Posted July 22, 2009 Share Posted July 22, 2009 Yay the Cordia! 1985 would probably be an AB model, from memory. They were the fastest but I don't think they had the vented front discs of the later models? You might want to deal with the cause of the white smoke first and then reassess the misfire situation afterward. The trusty Cordia GSR seems to have a hundred different common faults, like cracked exhaust manifolds or air leaks or bad vacuum lines or leaky injectors or dodgy sensors etc, so I'd assume nothing and start eliminating the easiest possibilities first. Spark plugs? There's still some Cordia gurus who hang around at the cordiapower.com forums - give them a try too. Quote Link to comment Share on other sites More sharing options...
Southern Hardstyle Posted July 22, 2009 Author Share Posted July 22, 2009 apparently had new plugs leads etc before hand but didnt get given much info. have been told the turbo is gone hense the white smoke. any ideas? plan on getting new plugs and give it a radiator flush tomorrow. dont know how hard it would be to find a new turbo for it Quote Link to comment Share on other sites More sharing options...
lowlancer Posted July 22, 2009 Share Posted July 22, 2009 White smoke usually means water does it not? BHG? Is the coolant mayonnaise like? Sounds like you've got either a fuel, ignition or compression problem, lol. Check plugs for colouration, check spark from leads, check dizzy cap and rotor, consider cleaning your injectors, replace fuel filter, check fuel flow, check compression So many possibilities Quote Link to comment Share on other sites More sharing options...
RT Posted July 22, 2009 Share Posted July 22, 2009 If it just puffs white smoke a little then it could be piston rings or valve seals.. if it's a lot of white smoke then it's probably turbo seals. Quote Link to comment Share on other sites More sharing options...
escortman Posted July 22, 2009 Share Posted July 22, 2009 white smoke is either water or burnt oil Quote Link to comment Share on other sites More sharing options...
Southern Hardstyle Posted July 23, 2009 Author Share Posted July 23, 2009 it is alot of white smoke, idles with just little puffs sometimes. but when u go to rev it theres heeaps of white smoke, but it still boosts nd all Quote Link to comment Share on other sites More sharing options...
fuel Posted July 23, 2009 Share Posted July 23, 2009 white smoke usually indicates turbo seals on their way out, it'll usually smoke white smoke as you are deaccelerating, especially after boosting it a bit. if it's blueish-white smoke when revving it, it could be piston oil control rings failing, or it could even be burning and clearing out the oil which is being sucked through worn valve stem seals after idling for a bit. best to give the motor a compression test, and determine exactly what colour the smoke is and exactly when it smokes. I have a TC06 Cordia turbo but it too has worn oil seals so will puff white smoke out after coming to a stop after giving it a cain. Quote Link to comment Share on other sites More sharing options...
