Toucan Posted May 19, 2008 Share Posted May 19, 2008 Want to top up oil but it's so impossible to get to in the small starlet tunnel. If I pour oil down the shifter hole and park facing downhill will it run to where it's meant to be? Have taken tail housing off before but can't recall what it looks like behind it, see diagram Quote Link to comment Share on other sites More sharing options...
mark105 Posted May 19, 2008 Share Posted May 19, 2008 prety sure it wont but ill pull mine apart and look tonight, infact you want it? E sold it to me for hundy but it has a gear missing a tooth, might be able to make 1 sweet one. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted May 19, 2008 Share Posted May 19, 2008 Oil pours out the tail shaft if you tip it up so theoretically it will flow through the bearings etc into the gbox case edit: unless for some reason the shifter is completely blocked off from the tailshaft aswell. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted May 19, 2008 Share Posted May 19, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 19, 2008 Share Posted May 19, 2008 yea poor it in the shifter will be fine Quote Link to comment Share on other sites More sharing options...
kpr Posted May 19, 2008 Share Posted May 19, 2008 always fill my t50 that way as well Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 19, 2008 Author Share Posted May 19, 2008 Yus! Cheers guys Quote Link to comment Share on other sites More sharing options...
durty Posted May 19, 2008 Share Posted May 19, 2008 my recomendation is to drill a hole through tunnel where the filler hole is lol Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 20, 2008 Share Posted May 20, 2008 Not that bad an idea, just make sure it's a hole the size you can get a rubber grommet in and bobs your uncle. Quote Link to comment Share on other sites More sharing options...
l1ttle_d3vil Posted May 20, 2008 Share Posted May 20, 2008 you should be able to fill it easy, just get a suction thingy with a flexi hose on the end. i managed to fill a w55 box in a ke25 tunnel no probs, and they're a tight fit Quote Link to comment Share on other sites More sharing options...
