removing axles
Beaver
hey all.
i need to take the axle/axles out of my hunter cause one of them is broked...lol. can someone fill me in on the hole slide hammer thingymabob? ive tried pulling on it with sum chain and then we tied a rim and tyre to it and threw it as hard as we could but it still wouldnt budge...haha. so yeh, i was hoping someone would be able to tell me that yes if i get hold of a slide hammer it will solve all my problems...lol
anyone?
thanks
wheres it broken at the flange wheel end or spline diff end,
spline end jack the car up put a spare wheel and tire back on and hit the inside of the tire with a full swing with appropriate piece of 4x2,
inertia from tire moving normally pop them out,
heat is your friend so a gas axe can help as the bearings in the housings can be tight,
if its the flange gone you'll have to weld a step to lever it out from the diff
in the centre
good luck
