peteretep Posted January 30, 2007 Share Posted January 30, 2007 Me and fuel just put a new engine in my Galant, just cant get the clutch right, it works alright but it disengages in about the first 5cm and it seems to be done up hard. The old clutch was all good and this one had more meat on it although it used a different pressure plate. Quote Link to comment Share on other sites More sharing options...
corrupt Posted January 30, 2007 Share Posted January 30, 2007 now it has that "race" feel eh? i know that on the cortina there is a spacer on the gearbox which the cable goes through, which if you dont have makes adjustment real gay etc, checked that? Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 30, 2007 Share Posted January 30, 2007 dousnt screwing it in give more "pedal"? Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 30, 2007 Author Share Posted January 30, 2007 more pedal meaning what? Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 30, 2007 Share Posted January 30, 2007 the clutch will disengage farther down on the pedal stroke. Quote Link to comment Share on other sites More sharing options...
davidian Posted January 30, 2007 Share Posted January 30, 2007 was it the same size engine before? why diff. pressure plate if so? and yeah try unwinding it if its done right up. it should drop the bite a bit Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 30, 2007 Author Share Posted January 30, 2007 yeah same engine(its just a daily after all), my one had done its dash (410,000kms with no work on the bottom end) It was a different clutch because we had another one there that had more left on it than the current one, and we used the pressure plate from it too, thinking that it would be bedded in properly I'll try turning it back tomorrow On another note, I got a guy to give me a price on clutch today at repco, he came back and said $210 for a 'clutch kit', anyone know what a kit includes? Quote Link to comment Share on other sites More sharing options...
thminiman Posted January 30, 2007 Share Posted January 30, 2007 pressure plate, release bearing, clutch plate... basically the only thing you wont get with it is a machined flywheel, which i would reccomend. Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 30, 2007 Share Posted January 30, 2007 yeah and maybe a spigot bearing.Mitsu seem to fuck out. Quote Link to comment Share on other sites More sharing options...
thminiman Posted January 30, 2007 Share Posted January 30, 2007 at least go thru BNT or something tho mang, wont rip you as much as ripco, and they can machine the flywheel for you too. Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 30, 2007 Share Posted January 30, 2007 damn, cam got me a HD exedy clutch kit with spigot bearing for like $170 or somthing.REPCO suck balls Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 30, 2007 Author Share Posted January 30, 2007 hook a black person up then au Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 30, 2007 Share Posted January 30, 2007 damn, cam got me a HD exedy clutch kit with spigot bearing for like $170 or somthing.REPCO suck balls I got a HD exedy clutch kit for my escort, under $120 from repco! Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 30, 2007 Author Share Posted January 30, 2007 seems I was getting scammed by the repco noob Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 30, 2007 Share Posted January 30, 2007 ive seen the exact same exedy kit combo on tardme for $250.crazy Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 30, 2007 Share Posted January 30, 2007 pm me all details if k33n pete. will look into one for ya. stock clutch = would be the go no doubt Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 30, 2007 Share Posted January 30, 2007 prob find its the same as mine mang.Maybe diff thrust bearing Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 30, 2007 Share Posted January 30, 2007 w3rd Quote Link to comment Share on other sites More sharing options...
fuel Posted January 30, 2007 Share Posted January 30, 2007 It's a '89 SC3H Galant GLX with 4G37 carby styles. Same as E32A import I'm sure, and others like Cordia non turbo, FWD Sigma 1.8, Chariot, Tredia etc. I just can't remember if winding out the adjustment makes the clutch bite earlier or later, would possibly make it bite far later. I think it was at max adjustment or pretty close too it, I couldn't get it to wind in anymore. Clutch kit includes clutch plate itself, pressure plate and release bearing which is the bearing I pointed out. Reason we used the other pressure plate was the original pressure plate was uneven on the surface and probably would have slipped with the other clutch plate which was worn differently. Like putting new rotors in without changing brake pads almost. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 30, 2007 Share Posted January 30, 2007 wind it out. giving more slack = brings pedal closer to the flo' Quote Link to comment Share on other sites More sharing options...
