ESKIN8R Posted August 25, 2006 Share Posted August 25, 2006 Im looking at doing a rebuild Plans - twin 40mm dellortos (have already) - bcf2 cam (hopefully getting) - 1300 HC pistons, slight oversize pistons - extractors (coby) (have already) How does this sound? Est hp? recomendations? Any advise or help would awsome. Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted August 25, 2006 Share Posted August 25, 2006 also lighten the flywheel, and a bit of head work will work well with those mods and you'll get a nice increase in torque and response. then you'll be flying Quote Link to comment Share on other sites More sharing options...
v3k Posted August 25, 2006 Share Posted August 25, 2006 Not so sure on the coby extractors - I have heard they are shit? But should be better than the stock manifold anyway. But a raise in compression, better induction and a more agressive cam is a good start. But with all engine mods - without a 'good' flowing head you wont get all the benefits. So some $$ on porting might be a good idea. Quote Link to comment Share on other sites More sharing options...
cubastreet Posted August 25, 2006 Share Posted August 25, 2006 pretty expensive to get these flowed as they're iron and take so long. If you've got a die grinder you might want to do what I did - find someone who used to do a lot of xflow heads and get them to do one inlet and one exhaust port for you, then do the rest yourself as close to that as you can. Took me quite a few lunch times at work but i ended up with a nice head for fifty quid. double valve springs would be good to get hold of too. Quote Link to comment Share on other sites More sharing options...
Jonny Posted August 27, 2006 Share Posted August 27, 2006 Or source a GT head as they're already worked, probably not much but its better than nothing. Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted August 27, 2006 Author Share Posted August 27, 2006 It is a gt head already, its a 1600 sport engine Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 27, 2006 Share Posted August 27, 2006 i spent about a grand working my xflow head. that inclused port/polish, biggest valves they could go, and double valve springs. plus crack testing, hardened seats and all that. not cheap! Matt Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 27, 2006 Share Posted August 27, 2006 pretty expensive to get these flowed as they're iron and take so long. If you've got a die grinder you might want to do what I did - find someone who used to do a lot of xflow heads and get them to do one inlet and one exhaust port for you, then do the rest yourself as close to that as you can. Took me quite a few lunch times at work but i ended up with a nice head for fifty quid.double valve springs would be good to get hold of too. Thats a real good idea if your on a budget. Also paying for the head to be crack tested is worth it. Quote Link to comment Share on other sites More sharing options...
Raizer Posted August 27, 2006 Share Posted August 27, 2006 pretty expensive to get these flowed as they're iron and take so long. If you've got a die grinder you might want to do what I did - find someone who used to do a lot of xflow heads and get them to do one inlet and one exhaust port for you, then do the rest yourself as close to that as you can. Took me quite a few lunch times at work but i ended up with a nice head for fifty quid.double valve springs would be good to get hold of too. Thats a real good idea if your on a budget. Also paying for the head to be crack tested is worth it. Concur! had mine tested before the ports were tidy'd up Quote Link to comment Share on other sites More sharing options...
Guest head_tech Posted November 25, 2006 Share Posted November 25, 2006 argh the old 1600 xflow, ive had a few of these and one close to your specs that put out aruond 110hp at fly wheel, the heads sure need opening up on those xflow motors and you can squeeze 2L valves in there to from memeory...its been awhile Quote Link to comment Share on other sites More sharing options...
