Guest ruthless Posted June 22, 2006 Share Posted June 22, 2006 im after info about doing a rover v8 conversion into a mk5 cortina. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 23, 2006 Share Posted June 23, 2006 Talk to sykov6 he has done similar Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 23, 2006 Share Posted June 23, 2006 thankx will do Quote Link to comment Share on other sites More sharing options...
mk5corty Posted June 23, 2006 Share Posted June 23, 2006 heard the 302 cu windsors a good one but that was for the aus mk5 dont know about the nz. Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 23, 2006 Share Posted June 23, 2006 thankx for your help i just picked up a v8 and auto for $500 running off a mate and hes going to put it in for me Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 24, 2006 Share Posted June 24, 2006 dman thats awesome problem with a windsor is the enormous weight, australian cortinas had uprated suspension thats why they handle them better, doenst mean they handle good though Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 24, 2006 Share Posted June 24, 2006 yea 302 are much better power wise but there alot more xepencive to its only going into a wagon so itl be a cruzer and the 3.5 is alot better on gas Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 24, 2006 Share Posted June 24, 2006 Even crusiers need to turn corners. Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 24, 2006 Share Posted June 24, 2006 ok? Quote Link to comment Share on other sites More sharing options...
crazy_rich Posted June 24, 2006 Share Posted June 24, 2006 chuck a lexus in it mate, it'll go hard. are you planning on leaving everything else standard? carby'd? Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 24, 2006 Share Posted June 24, 2006 yea just guna leave the twin su on it funds are tyt ay Quote Link to comment Share on other sites More sharing options...
crazy_rich Posted June 24, 2006 Share Posted June 24, 2006 sweet, should be a good skidder then. best of luck to ya eh Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 24, 2006 Share Posted June 24, 2006 yea il put some photos on when i get some the cars stuck in greymouth at the mo cuz of the snow Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted June 24, 2006 Share Posted June 24, 2006 i got some heavy duty springs i could sell to you cheap as. they only lows but with the weight of the v8 they should be just right. pm me if u wanting them Quote Link to comment Share on other sites More sharing options...
dylan Posted June 24, 2006 Share Posted June 24, 2006 a rover v8 wont weigh it down much there as light as shit Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 24, 2006 Share Posted June 24, 2006 Rover 3.5s are lighter than pintos, about the same as a crossflow from memory (but that could be the p76) Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted June 25, 2006 Share Posted June 25, 2006 yea apparently they are lighter then most 4cylinder cast iron engines. good luck to ya. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted June 25, 2006 Share Posted June 25, 2006 dunno about lighter than a pinto but definatly ligher than a ford v6. i had a mk2 sport with a p76 for a while in the days b4 certs . we just cut the firewall out sat the motor + trans in there and made mounts to suit. would never pass now days. but theres plenty of mk4/5 cortys gettin round with v8s of all descriptions. its alot easier in the aussie ones as the front susp/brakes/diff/ trans tunnel are all upgraded for the falcon 6 Quote Link to comment Share on other sites More sharing options...
Guest ruthless Posted June 25, 2006 Share Posted June 25, 2006 yea thyr pritty light itl fit in nicly just need to do mounts and chang the sump and shortin drive shaft. i wnt to find a ozzy assembald diff for it and pinto front disks. Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 25, 2006 Share Posted June 25, 2006 pinto front disks?? havent read up on them but why them? Quote Link to comment Share on other sites More sharing options...
