spacie Posted May 25, 2006 Share Posted May 25, 2006 ok so i wanna drop in a 1600...am i correct in assuming that its just a straight forward bolt in?like maybe a half day job?will my Coby extractors bolt up 2 the 1600? (i have a 1300) Quote Link to comment Share on other sites More sharing options...
Raizer Posted May 25, 2006 Share Posted May 25, 2006 is it out of a Escort or tina? the tina sump wont fit over the escort x member, if it doesnt fit you'l have to heat and hammer your 1300 sump so the rods dont hit the side of the sump, but you've got to keep the bolt patern the same. Other than that its a bolt in job, and you may need to get you head pipe extended a couple of inches so your exhaust clears the floor. Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 25, 2006 Share Posted May 25, 2006 Yeap as hellraizer said, the 1600 block is about an inch higher so the extractors may need extending. And correct with the sump, I have a early cortina 1600 in my escort and the sump hits the crossmember, but you can hammer the sump back carefully without needing to cut and weld it. Also if it is a cortina engine, use the escort flywheel and clutch assembly, as the cortina one has different teeth on the flywheel and a wider pressure plate. Only other thing I came across was the accellerator cable bracket, if you change the intake manifold or carb you may need to fiddle with the bracket to make sure it still lines up and works correctly. Other than that its a piece of cake Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 25, 2006 Share Posted May 25, 2006 Yeah was going to mention carb linkages. IF your going to have to stuff round with them might as well be stuffing round with a 32/36 version and linkages. Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 25, 2006 Share Posted May 25, 2006 Not sure but maybe also do radiator? Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 25, 2006 Share Posted May 25, 2006 I kept 1300 radiator, is there even a difference? My viscous fan on the waterpump wasn't in the best condition so I have a 10" electric fan aswell, and I've never had any problems with it running hot. Quote Link to comment Share on other sites More sharing options...
Raizer Posted May 25, 2006 Share Posted May 25, 2006 I kept 1300 radiator, is there even a difference? My viscous fan on the waterpump wasn't in the best condition so I have a 10" electric fan aswell, and I've never had any problems with it running hot. Yeah the 1600 is only 1/2 inch taller, i only had a electric fan on my workd 1600, but thats got a 3500 rover v8 core in it. Quote Link to comment Share on other sites More sharing options...
spacie Posted May 25, 2006 Author Share Posted May 25, 2006 for the moment i will use the carb setup i have on the 1300 (1600 intake manifold & 32/36 carb) and I had to modify the bracket to fit that sooooo it should b all good and then go 2 twin sidies Quote Link to comment Share on other sites More sharing options...
davidian Posted May 26, 2006 Share Posted May 26, 2006 how worked is the 1600? dont go sidies unles done the cam and head Quote Link to comment Share on other sites More sharing options...
spacie Posted May 26, 2006 Author Share Posted May 26, 2006 havnt got 1 yet...but i plan on eventually gettn cam,head etc done so yeah Quote Link to comment Share on other sites More sharing options...
davidian Posted May 26, 2006 Share Posted May 26, 2006 just go for the 2l bro straight up youve already got one and theres a guide there Quote Link to comment Share on other sites More sharing options...
spacie Posted May 26, 2006 Author Share Posted May 26, 2006 ahhh if u kept up 2 date with my Users Projects u would c that i have no 2L or parts cars... Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 26, 2006 Share Posted May 26, 2006 That would be my suggestion too mate, I went for the 1600 as I wanted the easiest, quickest fix when I replaced my 1300. There isnt tooo much difference in power, although in saying that I've only got a standard one. You will need a cert for your bucket seats anyway so certing for the 2l wont be any extra hassle. You can probably find a 2l for just as cheap if not cheaper than a 1600 aswel Quote Link to comment Share on other sites More sharing options...
davidian Posted May 26, 2006 Share Posted May 26, 2006 sorry, i just read there that you DID Quote Link to comment Share on other sites More sharing options...
spacie Posted May 26, 2006 Author Share Posted May 26, 2006 nah when i used 2 go 4 a WOF i would just bolt the original seats in & bolted up a massive granny as muffler with a 0.5 inch tip... yeah man the parts cars were farking crap as....so much rust etc & the 2L was beyond help. so 1600 it is. and i will just buy some new extractors (will get em HPC'd etc 2) Quote Link to comment Share on other sites More sharing options...
davidian Posted May 26, 2006 Share Posted May 26, 2006 dont put the dumpy back on dude. kills it Quote Link to comment Share on other sites More sharing options...
spacie Posted May 26, 2006 Author Share Posted May 26, 2006 hey man we all have specific tastes & i dig dumpys on old skool cars....looks tuff haha and i have an even bigger dumpy this time Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 26, 2006 Share Posted May 26, 2006 Yeah dumpys o oldschoolers FTW. Beats cannon muffs and just gay pipe out back. Quote Link to comment Share on other sites More sharing options...
MK2-8-U Posted May 26, 2006 Share Posted May 26, 2006 If it's just a standard 1600 there wont be much of a power difference,get a 32/36 for the 1300 and some head work Quote Link to comment Share on other sites More sharing options...
spacie Posted May 26, 2006 Author Share Posted May 26, 2006 1300 already has 32/36 carb....and i feel like throwing in a 1600 cos i can Quote Link to comment Share on other sites More sharing options...
