macabre Posted June 23, 2006 Share Posted June 23, 2006 L300 clutch ant vr4 flywheel Quote Link to comment Share on other sites More sharing options...
Blueex Posted June 23, 2006 Share Posted June 23, 2006 Have you checked that the starter motor, when bolted in place will contact the ring gear when starter is engaged? Also did you put a spigot bearing into the flywheel? Quote Link to comment Share on other sites More sharing options...
macabre Posted June 23, 2006 Share Posted June 23, 2006 gonna slot the the starter and built the thrust bearing fork up Quote Link to comment Share on other sites More sharing options...
Blueex Posted June 23, 2006 Share Posted June 23, 2006 Oh ok. If you use a L200 flywheel you wont have to do any of that. Then use a gsr skidma fwd heavy duty pressure plate with a L200 215mm clutch plate. I got a 4 puck brass button clutch plate made by autoclutch in auckland as i found that a standard organic clutch kept slipping. If you use the vr4 flywheel you will have to get the centre machined out to allow for a spigot bearing to be pushed in to support the end of the input shaft of the gearbox. Just something 4 you to think about. Quote Link to comment Share on other sites More sharing options...
macabre Posted June 24, 2006 Share Posted June 24, 2006 ill check it out cheers Quote Link to comment Share on other sites More sharing options...
Blueex Posted July 6, 2006 Share Posted July 6, 2006 Theres not much room for that fan a. Howd you get on with spigot bearing? Quote Link to comment Share on other sites More sharing options...
macabre Posted July 6, 2006 Share Posted July 6, 2006 havnt done anything about it yet Quote Link to comment Share on other sites More sharing options...
ProZac Posted July 12, 2006 Share Posted July 12, 2006 What car did you source a radiator from? I'm doing much the same conversion, and I dont think my stock lancer radiator will be up to it. Would like to know where to look, cheers . Quote Link to comment Share on other sites More sharing options...
macabre Posted July 19, 2006 Share Posted July 19, 2006 got the standard one 3 cored Quote Link to comment Share on other sites More sharing options...
ProZac Posted July 20, 2006 Share Posted July 20, 2006 Sounds like a bloody good idea, how much did that set you back? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted July 21, 2006 Share Posted July 21, 2006 I believe he got it done quite cheaply I'm just using a recored Sigma rad for my SOHC 12 Valve conversion Quote Link to comment Share on other sites More sharing options...
ProZac Posted July 21, 2006 Share Posted July 21, 2006 Ive got a radiator from a turbo rwd eterna, but im not sure it'll fit? Quote Link to comment Share on other sites More sharing options...
macabre Posted August 17, 2006 Share Posted August 17, 2006 I believe he got it done quite cheaplyI'm just using a recored Sigma rad for my SOHC 12 Valve conversion wasnt really that cheap, got it recored, new top tank, and outlets moved for 400 ish, i guess its like a new one now because its all changed. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 18, 2006 Share Posted August 18, 2006 Race me cunt Quote Link to comment Share on other sites More sharing options...
macabre Posted August 18, 2006 Share Posted August 18, 2006 bloody hell your engine bay is intense, so orange race you say, whats at stake then. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 18, 2006 Share Posted August 18, 2006 It shall begin at Picalilly Station, high noon. A race around the world, I say, a race around the world. The victor shall be rained gold from the sky and the fairer sex will be gifted a man of true prosperity and frivolity. Nah, hand job from a hooker. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 29, 2006 Share Posted August 29, 2006 What else comes with ya microtech? What are you using for spark? Quote Link to comment Share on other sites More sharing options...
macabre Posted August 29, 2006 Share Posted August 29, 2006 i have the coils/ign module that came with the motor. it came wih the loom already labeled, some vacuum hose and instructions for installation and tuning. you can get other stuff from them, just ring that fucken guy whose number i texted you and ask him what you need hes on to it. Quote Link to comment Share on other sites More sharing options...
Toucan Posted September 1, 2006 Share Posted September 1, 2006 Fuck it looks right at home in there, good shit Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 1, 2006 Share Posted September 1, 2006 mean progress man! Quote Link to comment Share on other sites More sharing options...
