Hemi Posted June 19, 2005 Share Posted June 19, 2005 ok im thinking about getting a starlet and 4ageing it , just cos i dont have the escort nemore and should have the 4age anytime soon , what invloved in doing this , links>? anyhelp apprecited Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted June 19, 2005 Share Posted June 19, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 19, 2005 Author Share Posted June 19, 2005 cheers man Quote Link to comment Share on other sites More sharing options...
Ned Posted June 19, 2005 Share Posted June 19, 2005 just making a short version of the site, itll cost $5000 if you do most (if not all) work yourself and will take at least a month longer then you initially expect. good luck Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 19, 2005 Author Share Posted June 19, 2005 5 grand ??? r u sure dude that sounds mighty expensive for something like that i can weld make mounts and everything all im gonna need to really pay for is the cert Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted June 20, 2005 Share Posted June 20, 2005 it didnt cost my mate anywhere near $5000 Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 20, 2005 Author Share Posted June 20, 2005 yea my m8 droped one into a hunter and it cost him nothign , minus the grand that the enigne and box cost him Quote Link to comment Share on other sites More sharing options...
Toucan Posted June 20, 2005 Share Posted June 20, 2005 Yea I'd have to agree 5grand sounds steep for what it is Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted June 20, 2005 Share Posted June 20, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Ned Posted June 20, 2005 Share Posted June 20, 2005 if you know the right people you can do it cheaper. problem is than nowaday's some people will charge $500+ for a T50 for example engine+box, 800 mounts, 200 diff, 1000 suspention, 600 exhauset, 350 cert, 450 those are just a few things you'll need. thats about $3500 right there and then you'll need brakes, clutch, radiator with plumbing, the numerous amount of beers too shout your mates but remember, when you start it you'll end up spending WAY more... might as well set some new plugs, new leads, oil, filters, new clutch, release bearing, pressure plate and the list goes on and on and on Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 20, 2005 Share Posted June 20, 2005 All the clutch stuff would need to be new anyway. And diff wouldn't neccesarily be needed, my friend has a bugeye with a 13B, mild port, and runs the standard 1300 diff, although he doesn't do skids Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 20, 2005 Author Share Posted June 20, 2005 i forgot to mention i that the 4age will be coming with a box on the end of it , o i c what your getting at now haha fair call i thought u ment labour etc i was like wtf man . itll only be getting things that cant be replaced with the engine in e.g clutch etc spark plug i can get for umm free lead last time i cheacked were freaking expensive so bugger that haha Quote Link to comment Share on other sites More sharing options...
Ned Posted June 20, 2005 Share Posted June 20, 2005 little things WILL come up that need to be replaced. good luck though Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted June 21, 2005 Share Posted June 21, 2005 a good way to go is drop the engine in at minimum cost and then when u have the money do the other things like brakes and shit and diff, do them then rather than trying t do everythng at once it will take forever Quote Link to comment Share on other sites More sharing options...
mutiny Posted June 21, 2005 Share Posted June 21, 2005 yeah and also unless its a rwd engine youll need a rwd intake manifold and shit Quote Link to comment Share on other sites More sharing options...
Ned Posted June 21, 2005 Share Posted June 21, 2005 and you might need to alter the firewal a lil bit Quote Link to comment Share on other sites More sharing options...
Muzzie Posted June 21, 2005 Share Posted June 21, 2005 see http://www.toyspeed.org.nz theres a few people there who have done numerous conversions and are full of knowledge. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 21, 2005 Share Posted June 21, 2005 and you might need to alter the firewal a lil bit you shouldnt have to, at all, if it's mounted properly. rwd manifold isn;'t essential , i wouldn't pay $300-400 like some guys are chargin these days, just get a fwd altered.... easy Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted June 22, 2005 Share Posted June 22, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 22, 2005 Share Posted June 22, 2005 use teh 4agze crank angle sensor type "dizzy" and aftermarket ecu, or, as i saw on toyspeed a wee while ago, an adaptor kit to drive the dizzy off the cam pulleys... on '86s you dont need to cut the firewall, if you use the gze bit, so really, you shouldnt have to on a starlet either.... not 100% though Quote Link to comment Share on other sites More sharing options...
