Ned Posted June 22, 2005 Share Posted June 22, 2005 how about we just all use the ze block... bugger n/a Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted June 22, 2005 Share Posted June 22, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Muzzie Posted June 22, 2005 Share Posted June 22, 2005 use teh 4agze crank angle sensor type "dizzy" and aftermarket ecu, or, as i saw on toyspeed a wee while ago, an adaptor kit to drive the dizzy off the cam pulleys... on '86s you dont need to cut the firewall, if you use the gze bit, so really, you shouldnt have to on a starlet either.... not 100% though And what just happened to the budget? That adaptor kit is interesting but still pricey and then could cause radiator clearance probs in a Starlet. Modding the firewall is cheap, easy and legal if you check with your certifier first. Callum Sledgehammer Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 22, 2005 Share Posted June 22, 2005 use teh 4agze crank angle sensor type "dizzy" and aftermarket ecu, or, as i saw on toyspeed a wee while ago, an adaptor kit to drive the dizzy off the cam pulleys... on '86s you dont need to cut the firewall, if you use the gze bit, so really, you shouldnt have to on a starlet either.... not 100% though And what just happened to the budget? That adaptor kit is interesting but still pricey and then could cause radiator clearance probs in a Starlet. Modding the firewall is cheap, easy and legal if you check with your certifier first. Callum the adaptor kit wasnt actually very expensive at all. I doubt this dude would be keen on a 20v anyways.... Quote Link to comment Share on other sites More sharing options...
