v3k Posted February 16, 2005 Share Posted February 16, 2005 I dont know anything about webbers... But there is one on my 2L beasty. When you take the big round (and plastic) air filter cover off it has two square(ish) inlets with butterfly valves in them. Am I likely to be able to find a model number on it? Or can someone give me an idea what it is from my (shite) discription. Also, How much are they worth. (not selling yet, but will) Quote Link to comment Share on other sites More sharing options...
jinx Posted February 16, 2005 Share Posted February 16, 2005 Likely to be a weber 32/36. Will probably have 26 and 28 stamped on the outside of the two throats. Model number I believe is typically stamped on a small tag attached to one of the float bowl screws and will probably list it as a dgav or something. The two throats open sequentially and there is normally an auto choke mounted on the side (two small water hoses passing out of an odd looking housing on the engine side by memory...). They seem to be selling on trademe for $40-$80 depending on condition and who wants to blow the most money on the day...! Quote Link to comment Share on other sites More sharing options...
Jerm Posted February 16, 2005 Share Posted February 16, 2005 yehait will be a 32/36 .... the butterflys you see are choke butterflys... Quote Link to comment Share on other sites More sharing options...
esky boi Posted February 16, 2005 Share Posted February 16, 2005 Yep, 32/36 and it'll have 26 and 27 on the outside of the throats. If you look down the bottom of the carb, on the flange where it bolts to the manifold it'll have the model number, but you probably wont be able to see much untill its out of the car and cleaned (depending on how dirty it is ) It should say 32/36 DGV or DGAV if its an auto choke one. Quote Link to comment Share on other sites More sharing options...
Toucan Posted February 16, 2005 Share Posted February 16, 2005 Yep, 32/36 and it'll have 26 and 27 on the outside of the throats. If you look down the bottom of the carb, on the flange where it bolts to the manifold it'll have the model number, but you probably wont be able to see much untill its out of the car and cleaned (depending on how dirty it is ) It should say 32/36 DGV or DGAV if its an auto choke one. What ^^ said, model number is on the base of the carb, the side thats closest to the rocker cover so you most likely cant see it till you take it off. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 17, 2005 Share Posted February 17, 2005 Can a 32/36 be made to fit any car? I suppose it would depend on the manifold right? I want one for the celeste, but don't wanna jump in and buy one before knowing it'll work Quote Link to comment Share on other sites More sharing options...
davidian Posted February 17, 2005 Share Posted February 17, 2005 Can a 32/36 be made to fit any car? I suppose it would depend on the manifold right? I want one for the celeste, but don't wanna jump in and buy one before knowing it'll work yeah, its just up to the manifold.. oh and the annoying throtle linkage thingy for the accelerator cable, which can be annoying Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted February 17, 2005 Share Posted February 17, 2005 I made a 32/36 DGAV (took the auto choke off) webber fit on my gemini Made a plate out of 25mm thick ali and had to hack the manifold out a fair bit and file everthing slowley till it fit nicley runs good had to rejet it smaller air correction jets did the trick. But you can probably buy an adapter like a red line one or somthing for most cars.[/img] Dont have any pics of the adapter. Quote Link to comment Share on other sites More sharing options...
