Everything posted by morkster
I'm no cert man but the cert man did say fail :-/
Those mounts have come up at least two or 3 times on ebay within last 10 years (searching rx2 on us and au ebay everyday).. Rx2 went front mount on s3 single dizzy, twin dizzy is side mount. Bottom line is oldrx you are one stud short on that side.
All the info I've ever known is that you can re-shell with ltsa consent/knowledge throughout the process. ..Please correct if wrong.
Thanks, now that i've read the comments and seen that^ link my mind is at ease : )
Thanks i got the last wof at vtnz. There's two tyre size and pressure placards on the bike so yeah, if it was a car i wouldn't be worried. I know nothing about bike wofs really.
Cheers, it's a s40 boulevard ls 650. Miata tyre page says 4.6% off on speedo. Yep 15" rear and 19" front.
Rear wheel btw.
I just got paranoid.. does anybody know about motorcycle tyre sizes for wof, my lams bike is meant to have a 140 80 15 but the bike shop could only get a 140 90 15. Can anyone tell me if this will be ok? Thanks
Put a 2 inch system on it with a reso before the diff and a dynomax superturbo at the back.
Blizzo's Mk2 Escort Sport of rust Discussion
morkster replied to BLIZZO's topic in Project Discussion
Body looks too far gone to me. -
Fuckin car looks so fuckin good it doesn't look real.
Good on ya.. that paint job sets off those wheels so nicely
That's so cool. NZ assembled too.
I would like to see an engine bay pic bey Cool car!
Steel Surgeon Manukau redrill hubs apparently. https://www.google.co.nz/?gws_rd=ssl#q=steel+surgeon+manukau
Dunno, but they 165kw.. bout 225? hp
I've got a eb xr8.. afaik the autos are open diff and manuals lsd - dunno about wags tho.
Sweet engine, looks like a 'Y' block which has the biggest ports and runners of the 12as; stage 2 port it, and it'll honk : ) Did the gearbox mount up inline with the original tunnel mounts or.. ? I'm pretty sure under the cowl vents were not painted black.
For the sedan steelies I will give you a good price and come and pick them up.. if you want, when you're ready.. : )
I would like to buy your sedan steelies and whitewalls if you want to sell them at some stage.. or put them on trademe.
Yeah mate it's a s1 box.. it says above s2,3,4 boxes have the remote shifter like your s3 box. Clutch size is dependent on flywheel size. Check and see if the input shaft splines are the same on your boxes.. if they are and you have an 8.5" flywheel then you can use your new clutch with either box.
Yep as above^ bottom one s1 rx7 and the top one s3 rx7 turbo.. they have different size clutches from factory; 8.5" and 9" respectively. Also Gaz twin dissy is side mounted off front plate with engine mounts while single dissy is mounted off the front cover with engine bracket and mounts.
Yeah they're a long way forward.. Early xmember is mounted the same only the engine is side mounted off the front plate.
Woops.
Your xmember looks like a twin dissy rx2 with extensions to fit 13b probly.. you can mount a 13b rx3/4 style (under sway bar) but will be way up front.. or you can mount it s3 rx2 style but your gearbox xmember will be way back then. You could keep what you've got; might be best and easiest I don't know. Those struts are probly rx2 as rx7 spindles are on a different angle and you end up with positive camber: http://www.rx7club.com/old-school-other-rotary-63/rx7-struts-rx2-734483/
