Everything posted by CorollaGT
Someone tried to jack the car up off them would be my pick
On my car I got hold of an old bung ECU and a electrician buddy stripped the connector off it and made an adaptor loom using that and the Link wiring harness so that it was "plug and play" with the factory engine loom. Then I hooked wideband wiring straight to the Link loom and done. Managed to sqeeze all of that wiring in under the dash so you'd never know. Just had the USB cable running up to the glove box for easy access.
Oh man, so jelly of that windscreen strip! Are they universal?
Do Sabelt sell 5 (or 6) point harnesses that can easily be converted to 4 point and back again? After all the race cars I've been in, I cringe each time I jump in one where they only have a 4 point harness. Find they're uncomfortable and struggle to get them to sit right - usually the buckle lifts up too high when tightening the shoulder straps.
Nice Matt, quite digging the gold on white.. those Weds Sport rims really set it off. As Rhys said, Willwoods on these are the shit. Wouldn't bother trying to get the twin pots to work. I tried TRD Black pads - nice feel/bite but couldn't handle the heat. TRW pads (about $70) were sweet for heat but didn't really have the same bite. Finally tried a set of Hawk HP+'s which handled the heat and had better bite than the TRW's but still wasn't happy with the bite (TRD blacks were the best there). Ended up getting a set of Willwoods off MRP (coupled with TRD blacks in the rear) and brakes are awesome. Pit straight at Taupo I'm braking at the 50 marker and you have plenty of time to get off the brakes and ready yourself for turning in. You can get Chamberlains in Christchurch to make up a bigger rear swaybar for about 280+GST to suit. Planning on doing this myself sometime this year if I can't get my hands on a Whiteline 20mm blade adjustable bar
Was considering getting one of these a few months back, so glad I didn't impulse buy like normal! Yuck. Brought a MagnaFlow muffler instead, holely fuck it's quiet especially seeing as its bloody straight through. Win.
JTune did some dyno testing with intake pipes, playing around with not only diameter but also length https://nzhondas.com/na-tuning/123153-intake-setup-all-engine-setup.html
Don't know if its been mentioned but the factory sumps have no baffling so if any spirited driving it going to happen it would be a wise investment to put a baffle plate in.
Palmy Monthly Burgerfuel Meet - Tues 16th Dec 7pm
CorollaGT replied to Sparkle's topic in Lower North Island Region
Ah fail, normal hours Tuesday, it's from Wednesday onwards... as you were -
Late night shopping in the Plaza from Tuesday the 16th till Chrissy. Still plan on meeting there and just trying our luck? -
I heard he was getting G-Zeros... Can't believe how shiny this thing is in person. Keen to have a go at the Corolla?
Fail post
Only the inlet on these
Palmy Monthy Burger Meet - Tues 18th November 7pm
Damn, thats a pretty fly Galant in the background -
If it's of any help James I have my old used TRD headgasket in the shed you can use
But not from last night haha -
The place is Chamberlains http://cobrasprings.co.nz/ Got a quote the other month for a rear sway bar and it was 285+ GST
l0wke's 1978 KE30's - Track and street - Discussion
CorollaGT replied to Truenotch's topic in Project Discussion
If you want to get either of them in the mag might be best to speak to a contributor if they're not getting back to you. Aaron Mai is in Palmy, he did Cole's RX7. -
http://www.lasertools.co.uk/item.aspx?cat=1259&item=5335 I got one of these and they are brilliant. There are probably cheaper options around but these are nice to use and makes it super easy
9 November Sunday Cruise: Pongaroa THE WAY TO GO
CorollaGT replied to CaMpylobacter's topic in Lower North Island Region
Pretty sure I won't have anything on that day so will be there -
A mate brought a nice shiny China-spec stainless manifold for his 2JayZee. Nicely made, tidy welds etc... then they did a magnet test and found while the runners were stainless steel the flange wasn't
http://m.ebay.com.au/itm?itemId=291257598512
Shall find out what chur'bro mate runs on his S14 circuit car. It's one of those Kinugawa turbos. Similar size to a TD05 iirc. Comes on boost nicely etc. On E85 was good enough for 300rwkw at about 20psi on an internally stock SR20DET. edit
Also auto 3S Altezza's had lower a compression ratio and less aggressive cams iirc
Nice driving Rhys!
