I was planning on using a w55 or w57 with a y series bell housing which should fit with out modification or very little and is the factory ecu that hard to use as have read they need a speedo input which shouldn't be that hard to overcome also a throttle switch on the foot pedal for the electronic throttle body, did you have problems with the height of the engine
thanks
