Everything posted by governorsam
yup, was easier, and i live on a hill which needs good brakes. morrie minor van, everything is the same. think i also used the legs too, they are stronger than the side valve ones. bolt straight in, no cert. also bolted the diff in too. the side valve wheels have a reputation for falling apart at the rivets. silly thing is, I'm about to change it all again to toyota stuff...
wheels came on another one i wrecked. appear to be morrie centers with proper new hoops with a rimlock on them. means i can run tubeless radials.
Dubman59's morris minor called george
governorsam replied to governorsam's topic in Projects and Build Ups
reassembled, fitted wider rims, replaced flathead motor with a morrie 1000 and ribbed gearbox and van brakes. -
angle grinder, wet rag on bits you don't want hot sparks on. or a die grinder. or drill then cold chisel.
http://www.trademe.co.nz/motors/boats-marine/parts-accessories/other/auction-389113547.htm this guy might know, has just put a 4.1 in.
un plug the 2 wires from the back of the generator, then join the terminals on the generator together with a bit of wire or whatever. hook your volt meter red lead to them. earth (battery -) the black lead. start the car up, should get about 15 to 16 volts from the generator. (or more) if not, gen is the problem if you do, regulator is the problem. or wiring. still run a gen on my morrie, they work fine on a stock car.
http://www.smackley.com/2010/02/my-zombie-van-is-for-sale.html like that, zombie removal...
will be at work too...
Any of you cunts keen for a cruise up to the go-kart track?
governorsam replied to RUNAMUCK's topic in South Island Region
http://www.stuff.co.nz/the-press/5194425/Police-have-frantic-Saturday-night-in-Kaikoura -
check the other wire has power, might be the sensing wire. check field windings on rotor first, just put power across the slip rings. should draw bugger all power and give a wee flash when disconnected. (bit like an ignition coils primary windings) unsolder the rectifier, get a reasonable size amp meter and check current draw across the different stator windings with a 12v battery. don't leave hooked up too long, or you will burn out your stator. current draw will be about what the alternator is rated at. ie 30 amps or whatever. this checks it under load, a multimeter can give false readings sometimes. the rectifier is like a series of diodes (one way electric valves) check them when unsoldered from the stator with a 12v battery and a headlight bulb. should have power one way, not the other. failing that throw it as far as you can, swear at it, buy another one.
the ballast resistor on an escort is a weird setup, a long resistor wire hidden inside the loom. by pass it, go straight from the back of the key and use an external ceramic resistor. don't forget the ballast bypass on startup either, usually the spare small terminal on the solenoid cap. not needed to run, but makes starting easier. sounds like you burnt the points out too. new points, new condenser, new resistor, new wires, should go mint. cheers.
alternator won't work without the warning light. find the small wire that goes to the alt, earth it out with a testlight - with ign on. warning light has 12v from key through the bulb and earths through the alternator field windings. no light working, the alternator wont fire up. or put a bulb between the batt + and the warning light terminal on the alt to see if that works. worth a shot...
http://indy.pp.ru/GDI/Docs/!Motor%20Repair/E/4g/PWEE9049-A_ENGINE_4G3_SERIES_WM/PWEE9049-A_ENGINE_4G3_SERIES_WORKSHOP_MANUAL.pdf http://indy.pp.ru/GDI/Docs/!Motor%20Repair/E/CARBURATOR/PWEE9007-ABCDEFG_CARBURETOR/PWEE9007-ABCDEFG_FUEL_SYSTEM_CONVENT_TYRE_CARBURETOR_13A.pdf
alternator light still come on? how many wires to the alternator? brushes are the most common thing to wear out.
last one i did years ago, i had the end brackets swapped around on the radiator to make it sit further forward. uses factory mounts then...
Datsun Queens birthday weekend minicruise. SUNDAY 5TH JUNE
the road is closed on the lyttelton side, you will probably have to go through the tunnel. http://eqviewer.co.nz/index-roadclosures.html -
need a front seat if you have one spare...
keen, i live over that way.
new to this, thought i might try and document the progress. LOTS of rust...
