Valiant
Everything posted by Valiant
  1. Valiant
    Throttle cable
    A piece of brake line bundy with something brazed on then end? I can turn the centre out of a bolt or some threaded rod if that is what you need. Or. Diggers brakes and cables?
  2. I may have a rim, a good tyre and a tube to add. Flip those bars. This bike looks sweet.
  3. It looks like it has worked out well. Does it drive nicely?
  4. Was it your one parked on the grass outside Super Cheap on Blenheim Road yesterday?
  5. Moving the lower arm sounds like a good idea too. You were looking to wreck this recently weren't you? I'm glad you didn't.
  6. Hey KPR, Why are you doing that? To alter your Ackerman angle?
  7. I've seen inside an Escort motor with flat top pistons. I think 85mm VW pistons were the ones to use in the past. Someone probably makes a new specific set now. The head was an early chambered head that had had a very extensive rework to increase the chamber design and depth. 1100 pistons are unavailable now? And make the compression very high? From memory. I'd keep the 3.5 to 1 diff myself.
  8. Toyota ones often leak around the top there is a shaped o ring and an o ring on the throttle shaft. It is quite easy to replace them both, just mark where the throttle lever is on the shaft before you pull it appart. You can get the parts from diesel repair shops they cost about $10 from memory
  9. Hey Matt this is coming on well. Your exhaust looks good in the photos, If you dislike it you could run it forward and around the front of the motor and down the left hand side. Maybe? Sucks about your LCAs. Has there been a rule change there?
  10. Yes that's what I thought, best to find out first hand though.
  11. Hi Cetus. These Milton steering arms to adapt MK2 Cortina Struts into an Anglia, Can they be used legaly in NZ? They are two pieces welded together by the looks. Thanks.
  12. This makes me laugh. A plate and paper swap across brands, audacious. It looks like it will be a cool bike when it's done.
  13. I asked about the trades job today but it sounds like they have found someone. I'll keep you posted.
  14. Lets just go for a drive some where/go to the pub etc. I've been to this before and was underwhelmed. Peoples cars being not welcome seems to go against the grain of Oldschool.co.nz.
  15. Yeah I would. If anyone doesn't like it it's their problem. This is a good idea too.
  16. You want me to price you a new one Mutiny?
  17. I don't think so. Bring your car and find out?
  18. Mondays Wednesdays or Fridays there Felix. Barge? I think you can walk maybe.
  19. You could look out for a NZ spec turbo too if you don't have one already.
  20. This is very cool, I really like these. Where did you find it?
  21. I've just mocked my calipers up at the moment, I think I will have a few clearance issues though. You could make up a crossmember to mount the shocks like a Mk1 wagon has.
  22. Try making some turrets for your shocks. Then you can move them in away from your brakes. Mk2 Escort ones are cheap and a good length.
