Well i have been recently procuring go fast bits of here and on trademe KPR was nice enough to sell me his direct port water injection setup with lots of added goodies
unfortunately today i realised i don't have the room to fit it as i had originally intended
i had originally intended to have 5 x injectors 1 in each port and keeping the superchargers rotors cool
the way i have currently set it up for is 2x small injectors are injecting just before the throttle body into the supercharger and 2x small injectors are set up just before the inlet manifold just after the intercooler
bit of faffing about to get the pipe that has the cold start injector on it that sits on top of the inlet manifold off i had to undo the 4 bolts that attach the super charger to the inlet manifold and there is 20 million things in the way/ no room to work
this is the 2 setup just before the inlet manifold post intercooler
and these are the 2 setup on the inlet to the supercharger just before the throttle body
i also mounted up the line pressure switch (if this stays on after the pump turns off i have a blocked jet) and the solenoid
also mounted the tank and pump in the boot
all i have left to do is setup the motor controller unit and wire the pump to that , install the pressure switch to start the whole thing and get some more nylon pipe to run between the engine bay and the pump
oh and i brought a civic alloy radiator but i need to get the bottom outlet modified to clear the engine mount
