bubblegoose
Everything posted by bubblegoose
  1. have you considered a honda motor?/2zz
  2. i have a peice of steel pipe welded to mine and its more comfortable than the toptul ones
  3. nope handles are a consumable i believe
  4. get some one to hold a rag/there boot over the exhaust see if the noise changes, that will confirm or rule out exhaust leak
  5. nay the 3m foam is pretty average the better brand is AES or AEG or something liek that in a gold packet
  6. dont shave it unless you plan on fitting 19's a massive sound system and moving the england any possibility of using the old boot wing and mounting it mid window? still think a dark green would suit this car (personal bias towards the 16v clio i used to own)
  7. it really depends on what is in it, it can range from $200 (white) to $2000(eg a pearl red) for the same paint but different colours all i have left is silver and white left for $80 a tin
  8. what makes it such an interesting colour is the massive amounts of powder pearl $$$$$$ i can collect left overs of oranges at work but will take me a while to get a full tin
  9. and the 4 stroke you manage to blow up?
  10. paint it with the left over green from your moped? also fyi the materials used to make the the exact ft86 orange will probably cost you more than the car
  11. the qcr curse
  12. may i recomend MIPA great build, easy sanding, minimal shrinkage and best of all CHEAP
  13. razor blade works wonders for cleaning it off glass, i use a quarter glass from a rear door and ive dropped it a few times and not even chipped it
  14. get in there with 3 good coats of 2k primer and sand that back, it will most likley come out good enough if not it will highlight the areas that need attention
  15. nice green
  16. keep heater core and make ducting for 2 bilge pumps from it give 2 blower setting for luxury comfort then mount somewhere convenient
  17. ignore all and any colours on dons bike, his stator has been rewired at some point hence the headache i had wiring it up. but also i may have swapped the stator over for the one on the donor bike so there is a 50% chance those wires mean nothing
  18. any 4 wheel drive place could do it (should atleast)
  19. i knew this would happen hence the booby trapped piston gang warfare has begun
  20. fa50s are supposed to be fagsmobiles your doing it wrong
  21. i see myself grabbing a hand full of stop and end up running some old lady over/its too engraved into my man genes/i occasionally go to pull the clutch in and change gears on scooters
  22. my die grinder skills aren't quite good enough to do a 5 angle valve grind might have to leave that for poofessionals
  23. turbo was selected last night, bairdy is out mugging large pimpster lookin fellas for loose change so he can purchase it, a mild clean up of the ports is without question even if i sneak in and do it myself while heavily intoxicated
  24. ouch, just jew up on some that fit from the random lead shelf in repco?
