xsspeed
Everything posted by xsspeed
  1. xsspeed
    This is most definately win, also keen to find out where can do it
  2. Wouldn't it be sweet so long as the quad throttle was sized equivalent to original. There is a formula to work this out, forget where it is though, something to do with effective area of individual throttles in use at anyone time.
  3. 6spd tremac from a FPV typhoon on TM for 2500 res, buy now 3k Pricey!
  4. Starter could be turning but not engaging into flywheel. As said give it a decent whack first - otherwise swap it out or rebuild Though from the above battery sounds pretty ill as well
  5. T56 from a new clubsport goes at around $3k + on TM I think the newer 6speed from the falcons goes for a bit more/is that a tremec box/cant remember/is expensive anyway
  6. Have you used any on your floor? Have been told that 500mls should give you 2 coats for a corolla floor as it spreads quite well. Think I will most probably get 1L and see how I go from there. Also GTO's are they 4wd then (being transverse?) just always assumed RWD I guess the gearbox issues will also be if you are sourcing from a commercial type vehicle, what the ratios are like and depending on what you get your diff from that ratio aswell.
  7. After chat on other thread, had quick read of yours to see what was going to replace engine. And sh\t, gunna be a weapon. Is the new vee engine alloy block? just asking re: weight distribution etc. Also is the convo above to do with sump for the engine to suit rwd? (from what I read the engine you are building is the fwd one?) also (may have missed it) but what gbox are you running. Cross members etc look tidy por15'd how much did you go through for that/how many coats/how much prep? (just wondering how much I should order/am also doing floor)
  8. I used to have repco 13" hubs cable tied to my corolla(13" wheels though). Was most lol/feared for my life when they got brittle and flew off
  9. Hubs would be ultimate nana spec Looking so sweet though
  10. Matty B IC looks so sweet/can't even see it/tidy looking 1e powered starlet bowl
  11. On that note just saw beaded seat cover. Mean
  12. Out of context, lol So choice, +1 for never wash
  13. damnit beaten +1 for the above though
  14. Should've compared spring heights while out, as kyteker said taller front left would have made rear right look low
  15. Oh cheers for that, I think the best bet will be just to wait for some to pop up, purchase and play around with them. If I cant make it work I will just flick them on/profit
  16. Fuck. looks like I will be getting some 40p's then
  17. Funny you should mention that, I have also noticed the same trend in my searches, didnt realise there was an e30 race series though, no wonder there are so many stock e30 wheels for sale. Will just keep trawling TM as not in a hurry, hopefully something comes up
  18. Have been looking at 15x7s in 40p I would like the same width in 25 p but might end up sticking out too far. No idea on tyres yet, was going to wait and see on that. I have a set of suspension and springs at stock height, and a lowered set from an fxgt, they are pretty low though (yellow springs so am assuming they are kings superlows or some rubbish), plan to get coilovers+adjustable so could adjust ride height to suit. Trying to massage the guards as little as possible but it may be inevitable for anything wider than 6". As above for wheel size, yeah I need to see whats available, havent seen much on TM lately for 25p, second option is just to get some 40P lightweight 15x7s. CP035s or something like that
  19. Yeah thats what I figured, just wanted to make sure I wasnt overlooking something glaringly obvious
  20. Oh Hai I want to get some reyums for my corolla. Its an ae82 liftback, 4 x 100 and from memory 35-40p offset. Question I have is, if I whack on some 25p wheels am I going to have any clearance issues besides they may stick out too far/rub guards? I really want to put something period/older on it and the best "JDM style" 4x100's seem to be in 25p. Semi rwd offset. I'm pretty sure there is one ae82 liftback in auckland with something oldschool on it, and they stick out a bit, but havent seen the car standing still so cant see what they are. Help appreciated. (This got a bit more tech orientated as I wrote it so mods feel free to move/flame)
  21. I think it fits but to get a proper match requires porting. One of them has a sort of 'D' shape iirc. Can't remember which one
  22. I have a rotary buffer that I picked up second hand. Don't really wanna use the clothe thing thats on it though cos I don't know what products have been on it. Does repco/supercheap stock replacement ones? can anyone recommend a brand?
  23. True? Learn something everyday. Maybe thats the case for the pre-HJ ones? I have an HX and an HZ both twin lights. Those are the only models I look at
  24. Don't prem's have twin headlights. Mine does. Every other one I've seen does
  25. Does that $10 per night get you entry too or nah, still $15 per day?
