bigfoot
Everything posted by bigfoot
very common problem on those is the ball joint on the end of the front lower control arm wearing. i lost count of how many of those arms i replaced on 12 month old galants under warranty when i worked at mitsi
do they have the same oil dripping rail thing over the cams as sr20's do? if so they are probably blocked and the squeek coming from the cams. i know of a few sr20 motors that have destroyed heads/cams because of that
Whangarei Meet...Time/date/location discussion.....
bigfoot replied to MACKAZ's topic in Upper North Island Region
if anybody can organise people my house is a good venue for eats/meets. i don't have internet currently but my cell number is 02102542502 -
keen as just say when and il show -
my boss sugested that after he couldnt figure it out either (im a mechanic)
thats the plan at this stage. im making a pipe going from the hole in bottom of distributor to the dipstick hole and store dipstick in car
definately not the o-ring because there is oil inside the distributor no roll pin, took the rotor off but had no luck in taking off reluctor(cant remember what it called but the steel block that tells the ecu when it is at tdc etc) looks pressed on and pick up inside says DO NOT REMOVE
i have a mx83 cressida and on the way home on friday it started missing under load. long story short: epic amounts of oil leaking from the distributor cap, pulled the dissy out to replace the seal and can't pull it apart. has anybody replaced the seal on these or is it a replace the whole thing. this thing is my daily and i live 17km from work
Any weekend suits me except weekend of july 4th -
Christ, where do these cunts come from I'm throwing a vote in for low boost high compression turbo set up. Failing that, some 20V tbs, a kpr spec exhaust manifold and a decent ecu. This is gonna be one to watch sounds like my plans for my lancer. fuck turbos
don't have space or transport for more cars. already got 2 in neighbors paddock (not lancers though )
the haynes manual has a good wiring diagram in it and heaps of other useful crap. the gregorys manual has all the wiring on 1 page ftl. i bought both for my lancer
let me know if you part out spare car. i'm after a few parts for mine
the 4g63 in my lancer had points. found a magnetic one that needs a rebuild
keen as whenever as long as it doent clash with speedway. also keen to sit in purpz getting towed through middle of town for lols edit: should be a weekend, more chance of cunts showing up/epic cruise -
the only 6g7x 2wd tritons i have seen are a few of the new shape ones and iv only seen 1 manual so gearboxes may not be cheap anyway. i drove alot of those tritons when i was at mitsi
i hope not to use spacers, but they are on there currently so it sits alright if someone could measure their mounts as a comparison that would be cool what did you do to fix it? put a bit of pipe down by the mount on the cross member and bent it up (speedway car) motor only lasted 3 races anyway
we had similar probmles when we put dylans old road car engine into 1 of the bosses dirt car escorts. apparently the cortina block is narrower
Whangarei Meat 11th March 6pm Regent New World Carpark
im in the same boat. can't afford/get time off work -
UPDATE time. i have basically havn't done alot to the car for age so i got off my arse and: -stripped the front suspension -painted one side of it -ordered new ball joints and wheel bearings (grease shouldn't be brown and lumpy) Found that the struts had the inserts replaced before i got the car and all the bushes too i will post some more pics when i find my camera
remove the torsion bar and rotate it 1 notch in the splines.did that on my old l300 worked mean
how many o/s boes are going this weekend. anyone wana setup a meet/convoy to go over or a meet over there for the out of towners
is this the corona that was in the skid comp at the nats with the mean as exhaust
keen as. might need to remind me a bit closer though lol -
yup its white for now. it had a blowen headgasket when my boss bought it from a customer at work lol
