Everything posted by cletus
- 128 replies
- 37
Maybe that's where the "harley stomp" shift technique comes from? Must be getting pretty close to rideable
Even better, 3 year wofs
- 800 replies
If you need more cooling so you have a bit of a safety margin, have you got room somewhere for a smaller radiator in the air flow at the front?
I did a job on a rear engined front radiator car a few weeks ago that got a bit warm, the owner reckoned the factory water pump didn't have enough beans to move the water enough at lower rpm
So the new joints arrived this time but they were packaged incorrectly and for a different car. Because the theme for this project is buy things at least twice I ordered some more of the 'correct' ones and am now waiting for those to arrive. I was bumbling around in the garage and looked at it and thought 'I wonder if the spindles and brakes fit the other way around ' as the mount holes for the balljoints are angled. Swapped side to side, did a bump steer check , that got it down to 13mm, it had what appeared to be a shit ton of caster and the top ball joint was getting close to binding, so adjusted the top arm a bit and rechecked it, down to 5mm now with camber and caster in the ballpark Other people are having xmas parties, I'm in my garage quite excited at improving my steering and suspension geometry, what a nerd
- 128 replies
- 45
Kia ora Cuz Te waka is looking tu meke. Ka pai. Bleh
Cars have to have a safety standard marking on them, cant find entry requirements for bikes so I dunno. @MopedNZ may have some input
Polarity is correct?
Today's job was bolt all the steering in and check bump steer Holy shit it was terrible. I've never actually bolted it all together with this combo. First check was over 70mm. Mucked around with different combos of tie rod ends and rod ends for hours and found the combo I have wont work so I I've ordered some different balljoints, the american balljoint has a slightly longer steering arm and the bit where the tie rod end bolts on is slightly higher. I was trying to use the aussie balljoint for quicker steering, my vg had needed a lower outer pivot to fix the bumpsteer so I was hoping this would be the same, but it appears to need the opposite. it looks like the ideal pivot center is right where the arm is
- 128 replies
- 21
Man that car park incident would boil my piss
Yep copper nickel or normal steel tube is ok, straight copper tube is a no go. stainless has to be done by a pre approved company or person
- 128 replies
- 45
- 128 replies
- 31
Drag day 12th December even if you are not competing, is a good time
I like the fact that you could not find the right vehicle to suit your needs so you just made one. Good work!
Yes, does require cert for welded parts like that. You can fit bolt on things like strut braces without a cert though https://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf This has all the stuff you can do that does not require cert
Should be fine, strengthening the factory structure is never usually a problem unless you start modifying areas forward of the suspension mounting and messing with how a vehicle crumples in an accident That doesnt happen very often though as theres not usually any reason to
No, I did some internet research last night and ordered a nippondenso type one off rockauto
Today's job was to bolt the trans to the engine, fill the converter, figure out what starter I need, (there are Australian and US spec starters with different size pinion gears, mine needs a us spec one so that's good cause can get a gear reduction one off rockauto) , make a dipstick tube fit (fingers crossed this works with the firewall and exhaust clearance which is fuck all) , bolt the crossmember on and knock up a trolley to put it all on. The plan is to lift the body up and roll everything under the car to fit it, to avoid damaging painted parts
- 128 replies
- 36
For sale if anyone is after a tent that needs wofs https://www.trademe.co.nz/a/motors/caravans-motorhomes/caravans/up-to-12-ft/listing/2871792869?ed=true
cletus replied to johnnyfive's topic in Upper North Island Region
I'm going to fight you like an upset teenage girl , crying and slapping you -
Must be a bmw thing , saw a woman driving a bmw SUV yesterday with wires hanging out the edge of the front tyres
Yeah that's the worst thing about china tyres, I have some cheap 265/30/19 on my falcon which are terrible in moist conditions
