CXGPWR
Everything posted by CXGPWR
Palmy/Welly Combo Meet - OTAKI December 1st
CXGPWR replied to KKtrips's topic in Lower North Island Region
so keen for this, should be a good meat, have been lacking on the os front for a bit so will definitily attend! also i know of a good area for a photo shoot/park up etc. and has plenty of room and is relativly private but still within a 2min walk to the shops on the main drag -
Also keen for otaki meat. -
MG Classic at Manfeild (formerly Whittaker's): 12-13 Nov.
CXGPWR replied to Shaz's topic in Lower North Island Region
I shall be attending both days, will be staying in palmy Kk? u thinking of BBQ and drinks at my place Saturday evening? Might even have the spa going by then maybe..... -
Grab some threaded rod, bend, cut, done. Not ideal but have seen alot worse, ALOT
Will be attending, also if people need free accom stz for GC let me know, gotta spare room and not too hard to put a bed up for people -
Id be replacing the distributor cap and rotor, had a city once, every so often out of the blue would fail due to cap and rotor even though they both looked to be all good. Replace them, sounds like the same problem ive come accross
Lolz
Banana Skidz in no time at all! Happy fun times
Sunday 2nd Oct shindig at Ed's. Short notice is how I roll.
CXGPWR replied to 0R10N's topic in Upper North Island Region
Keen as, Have spare seats for people that want to get sloppy and i dont mind having to drive people home(not toooo far though), just let me know! Ill be there anyways -
How about a leaky TX3 ???
Slave cylinder is off a ford mondeo, nice little unit, next time ill just make a slave cylinder though
So after some slacking off and some headaches i decided id change it up a little bit, I decided to mash a concentric slave cylinder in the t50 bell, reduce all the bits i was lacking like the fork, release bearing carrier and release bearing. So i went to pick a part, found one and after removing the box i had a factory concentric slave cylinder which cost me a whopping $10! Did some machining and modifing and wham! Job done! Also using flexable lines, couldnt be bothered with ugly bundy tubes, flares and all that shit. Also made the bleeder remote so no need to crawl under the car to blead the clutch! Now it can chirp a wheel without much effort at all. Next step 4Age 20v Pics
Looks awesome!!! Roll as is and read the wof specs to see how much you can get away with(Which is quite a bit) = less work to do, more rolling ratty as All in all WIN
Depending on how the link is set up orignally with its base timing that may need to be corrected. The ignition map should have been done when it was on the dyno, but its not hard to have a quick look at what your map is set up with. I have timing light etc so am happy to lend a hand man.
Possible car pick up with in the next few days? Auckland
CXGPWR replied to Seedy Al's topic in Upper North Island Region
Can collect it after work and stash in my garage, safe, sound and dry, u should have my number -
Down for fri up
If its stuck in hamilton then its not far away really, but yeah thats the problem with pick a part
Auckland OS cruise to Miranda hot pools - 11th Sept
CXGPWR replied to EURON8's topic in Upper North Island Region
I work at The toy shop, Grey lynn -
Pick a part in auckland is your friend, im not too familar with mitsis but surely there would be a FWD Sohc at pap and only cost less than 100 for a short block, But not sure how interchangable they are? Actually MOTOR, 4 CYL ASSY (NOT INJECTED) $174.00 BLOCK PETROL SHORT NO CYL HEAD $82.00 And there is plenty of stock at pick a part for a 2ltr engine so thats cheap??
Richie, can probably sort you a wof out if i take it into work and do it in a lunch time? or if you can bring it in at lunch time sometime, i completely forgot to ask boss bout weekend WOF's Will flick u a txt tomorrow! Im down for this though, sounds ideal, also 3 seats free in the suzuki lol -
Cam's Toyota AE86 Trueno Racecar - Yes, Another One!
CXGPWR replied to Ned's topic in Project Discussion
He may or may not, but i have all the gear to do anodiseing aluminium! Its a fun process for sure! -
Anyone with a ute or access to one keen for...
CXGPWR replied to Snoozin's topic in Upper North Island Region
Bro, i have the mint'st of mint vans that runs on LPG!!!!!!!!! welcome to it anytime, also its not too bad on the hills as the torque is just massive! ill make sure it dont smell like rubbish if you wanted to use it. Or another option is to take trailer down with markku's saab, and come back in markku's / slacker.cams bluebird wagon?? -
So tonight i mashed the t50 behind the 3a, found a couple of things to be needing some attention, Clutch fork is fucked starter motor will need to be spaced back a bit Need to cut the floor to allow for manual shifter also seems to me that the throw for the release bearing is not enough or what it should be, maybe later in the week ill get some more motovation and pull the t50 out again GRRRRRRRRRRRRRR Ill get there Anyone got a clutch fork for t50?
^legand! I'll be round 4 sure! Jammin the t50 in tonight!
Feel free, most the time in in the garage working on shit! Im in grey lynn, nice and central just up the road from western springs, gime me a yell 027 262 9068
