QCADTA
Everything posted by QCADTA
just looking at your ignition setup, whats the ignition module mounted on? these get hot and over heat if not mounted on a heat sink with a bit of heat paste in between etc, and cause the issues youre describing. It could be when the ignition module cools back down it restarts fine, fire it up and see if it gets hot and youre problems start when it does.
is your radiator cap lower than the top hose? hard to tell from the photo. if so this could create an airlock causing your issues. Try raising the radiator so the caps the highest point if it isn't.
Do you have a alternator warning/charge light on the dash? if its glowing very dim good chance a diode has gone, the more that blow the greater the glow, or if you have a multimeter handy, put it on ac and measure the voltage from the B+ term of your alternator to ground, this is measuring the dc ripple, with your engine running it should only be 0.5v ac, any thing greater and youve most likely got a cooked diode . whats your connection like between the back of your alternator to the battery post? if its shit this will overheat ya alternator and cook ya diodes.
is the wobble more on the left front than right?
Yeah took it for a run round the block in the weekend, done about 50kms in the four years since it was road worthy. Just got to get off my arse and take it in to get some stripes put on it. The mk2 seems to take up most of my time.
Ive got a bosch 910, in the boot beside the tank, no swirl pot, works well with a escort tank. Had no problems with the fpr but as said they are noisy pumps. Are you sure your coil packs arent breaking down under full load? Or just looking at your build thread, is your AFM straight on your turbo? they like a bit of length between them so the turbulent air does mess with afm. Mine used to cough a bit up top until i changed it.
this is a common problem for old escorts, your rack and pinion internal bushing will be flogged out. I replaced mine following the haynes manual, piece of piss if your slightly mechanically minded, whiteline make them. http://www.whiteline.com.au/product_detail4.php?part_number=W11113
Also managed to fit in the oldmans ff2000, not really made for people over 6ft but alot of fun, running a 200hp+ pinto.
New year a new colour. Just sorting the stripes. thinking black with white on bonnet, but also keeping orange all round. Opinions welcome. Also got another two escorts now, 2 mk2 2 doors, one a spare shell for my race one im building, already has arches, 4 link rear with watts linkage, turreted, adjusties etc but thought I should get this back on the road first.
Dont use por 15 where the sun can get to it, it doesnt like UV and have seen it turn to a shit powder unless you paint over it.
Get a Gizzmo coil to square wave converter off trade me then if it doesnt run on a coil pick up.
your distributors electronic (points less) but you run a coil with it? just connect it to the -ve side of coil. whats the resistor for, to cheaply convert tach signal?
if your after more caster get concentric top mounts or just take 15mm out of ya arb to pull the tcas forward more, like this and then lower the front of the arb with something like low n slow did.
looks awesome mate well done, that is indeed a nice stance. Your working rather quickly!
Gostlys 7agte 20v ae85 built on student allowance.
QCADTA replied to ae85 fiend's topic in Project Discussion
very nice mate. Love a budget build being as tight as i am, looking forward to the numbers. -
looks like its going to be a good project mate. I reckon the beams would be ideal for it, as said cheap and reliable. As said open class needs an open budget. The smaller engine classes in the clubmans down here look like they have the most fun, closest racing, and its not costing a fortune. Ill be going 20v 4age in another escort for this reason.
étude "Michael0008" B6D to BPT to KFZE to KLZE
QCADTA replied to michael0008's topic in Other Projects
may be a silly question but ya fans are blowing not sucking being mounted on the outside? -
if its not bad aryldite it mate.
Thats good to hear mate. Nothing like a win on a sunday.
not a problem, let us know how ya get on. When i say undo, i mean just loosen it enough to turn the dissy.
So could it be a vacuum leak? usually adjust timing by undoing bolt that hold dissy to block and turning the whole dissy while keeping an eye on the timing.
nice engine build, how much was the sq water kit? seems a shame to do a nice job then have the dizzy stickin out the front, why not run the honda da17 cop's? For a thermostat i was lookin at runin a bmw remote one, think theyre arouns 71deg so about the same as a trd one.
no worries, i went the cheap n easy way and just bridged the factory binary divider nissan uses to calibrate it, not my pic or settings but is simple to do.
how longs ya car been sitting? i see the link says 14.4v but give the battery a good charge and try again. had this happen before but not quite as bad as yours, battery seemed fine and car started and alternator was putting out 14.4V, but needed a night on the charger to bring it right. also had this on a pinto race engine, i know its not efi, but as the revs reached top end it would miss and fart as the battery wasnt giving the coil quite enough volts to keep her happy but ran fine up til top end, just a random thought.
thats awesome. youll be itchin to get back out on the track.
