Spencer
Everything posted by Spencer
  1. Ah yeah you shouldnt have plugged all that in and just hoped it works. The ECU's and body looms will have different ways of powering things, you could be poking 12V into things that shouldn't have it and fry them. Really should have done a full forensic check of how the existing all works and what wires do what and then match that to pin-outs for the 1gge. I figure the main relay shit will be different which is always a trap on this era of Toyotas, the ECU switches power for a bunch of things (idle control, maybe injectors etc) its not switched off the key.
  2. Generally with modern shit the coolant lasts forever (200,000km) so usually put OEM in there because that is what is already in 90% of post say 2005 shit. Depending on brand of vehicle its pretty much same price as chain parts stores.
  3. MIx up like 4mm of paint and see how long until its hard. I have used clear in the past that you can sand super quick, it all depends.
  4. Yeah you can save it, watch some youtube videos if needed of how pros tackle fixing clear. I have made a mess of clear in the past and wet sanded it back and put more clear down a few days later, its not ideal but its not a sin. I mean really all the hard work is done getting it flat and in paint, whats a few more days of work in lock down to get it super slick.
  5. Yeah in honda land people tend to run urethane mounts and maybe a torque damper, has a little give but engine cannot tilt forward and back f-all.
  6. A bunch of torque dampers for thought below. https://www.swapshopracing.com/contents/en-us/d1425_Ingalls_Engine_Dampers.html
  7. For FWD shit it makes a amazing difference to gear shifts having solid mounts, everything just feels better mechanically. IN the honda factory k24 world factory things have pretty floppy engine mounts, common mod is a engine damper which I have messed around with (you can wind them up to solid spec), makes shifting and throttle feel (engine not flopping around with throttle input) way better. Downside is more vibration (NVH), if you solid mount it all then possibly crack some things depending on the setup. You could probably bang one of the many dampers out there to your setup very easily, they are like $150ish, you get no rocking back and forward plus don't have to make new mounts yet.
  8. Spencer
    PAINT THREAD
    6 years ain't shit on a car. You can get zinc 2 part epoxy if you wants the zinc.
  9. Spencer
    PAINT THREAD
    No single stage paints allowed son.
  10. Agree, as I said earlier if It was my car I would spend the money on custom shocks. Fucked around too many times with off the shelf ghetto swaps and you get what you pay for.
  11. Shocks that are short enough for a lowered live axle car plus have the valving and end types you want are not that common TBH IRL.
  12. Probably 98% chance of yes. From memory the hilux spring rate is something like 12kg/mm, what do you think the spring in there now is? 4-6kg maybe? the adjustment usually wont cover that kind of range.
  13. Yeah just eyeballing them the body is much longer than that hilux shock, stock 86 shocks were too long for lowering most things (crown or waka). Just get someone with a lathe to shorten them up and keep it on the DL for a cheapish solution (I have no idea on legality).
  14. For the buick I tried all the shocks but never got the valving right for the 2" dropped springs. I was lucky that you could get custom adjustable fox shocks for the impala off the shelf that worked, boom problem solved every bump is soaked up and caught no bounce. I would be shelling out big coin these days and getting fancy shocks for anything old I owned as cars that ride like shit make me hate them eventually. (can get fox shocks made for any combo) For toyota shit the only off the shelf winner combo was MR2 rear shocks in the front struts, I could never make other fitment rear shocks work and stay captive (on live axle things). I ended up getting stock or fancy ae86 shocks shortened for like 3 different cars in the end, just did a dodgy with old mate vvega and chopped the shaft down and welded on a new end, just don't tell anyone.
  15. Dude the hilux shocks always seem good on paper as they are short and have the right ends for heaps of applications. But every-single-time they ride like shit, they are valved for real high truck spring rates so behave like concrete shocks on normal cars. Think there was recently a GX60 guy on here who had hilux shocks, bounced down the road doing fuck all suspension things until he changed them, I tried them back in the day and they are toilet.
  16. Yeah as the guys above were saying, even for a skilled electronics type person making something like that dakota box would be insane. Like hundreds of hours, hundreds in parts then it would break. Gotta pay the boss costs to have nice new trans in your old whip. I have got 3-4 different dakota bits for fans, cruise control etc over the years and they are top notch.
  17. Yeah the Dakota digital one I have seen in action and seems pretty good. Was like $300US last time I looked which seems pretty reasonable to just make shit work
  18. Yup but for old shit the rockauto shocks (munroe or gab etc) are valved like factory, so very soft and basically useless unless you riding all stock IMO.
  19. Yup this is where I was going with my ramble. It now has hotter intake air and more load it idle which could tip it over the edge, especially now its diagnosed as sitting on the thermostat while moving, that points to not enough air flow and/or radiator. The hose diagnosis is a good one, will narrow it down real quick.
  20. Form that it sounds like a fan flow or rad size issue then? How hot are you letting it get when sitting? on some horrible inefficient thing like the buick 455 with a 90 degree thermostat it would always sit on that temp while moving. Even with the monster mechanical fan and new rad it would climb to 100-115 when sitting still, just part of life with a big hot donk (the thing was rebuilt so new everything). Could sit for 30-40min on a hot day in traffic like that before I would chicken out, unnerving watching something go over 100 that but its within spec with a pressurised (old shitty) system. I put massive (spendy good ones) electric fans, made a shroud and a controller thinking I could keep it down more in traffic but they were way worse, on all the time and climbing temps way faster. Moral of that shit yarn is the rad size is bordline for the heat output of that motor and the fan air flow made a huge difference. probably not really helpful here, but maybe you maxed out your rad/fans? seems like with just the blower though you wouldn't have pushed the cooling system over the edge that much and it seems weird it goes nuclear in a minute. Edit: Looking again at the pics closely and IMO the rad looks pretty small and fan setup sub-optimal?
  21. How have you got the MREL setup? I thought usually ISCV and other stuff is powered by the main relay which is ECU switched? Usually still starts if that is done wrong though. Sorry not much help, maybe try getting a scope to check what’s actually happening? They are pretty cheap now.
  22. I don’t think weld through primer is any good from my experience, most rattle can paint can fuck off. 2 part epoxy works better IMO it holds out to heat just as well, pretty much invincible haha. Only catch is you want it to be cured well before welding so got to wait a day or two. You remove it from the weld area though, use a spot weld drill to remove if spot welding some seams together. Put it on the back of all your patches etc. Paint something in weld through primer and leave it outside, I did and it didn’t last that long. By that test it’s garbage.
  23. Yeah lush whip. Just a thought, if some dweeb has whipped out the thermostat then you would guess it got hot at some point (unless just total durp) if you say the water was gross then high chance the rad has some shit in it, would look into getting it cleaned at minimum. So many old radiators you assume are sweet can cock you over once you load it up.
  24. Need a quantum muffler to have max flow and no noise, 3" size only.
  25. Lol entropy muffler, that is all mufflers? all things apart from life maybe? They have some more surface area and some venturis hence more entropy? where the data?
