Everything posted by Raizer
Raizer replied to yoeddynz's topic in Project Discussion
I was under the impression that they were a total no go in general unless factory fitted? I'm looking into ways to modify my Merc mufflers and hide a pair of valves in there, was told to hide the cables and controller well/try to convince WOF guys they are factory fitted AMG options haha -
That's a lush muff! I've used FMF exhaust packing sheet on a couple bike mufflers, seems to hold up well and the packaging says it adds something like 4hp haha Got any plans on how to hide the valve actuators etc for cert/WOF? Could try make the cable look like it's coming from an O2 sensor lol -
"Compared to conventional type bolts, torque to yield bolts offer the engine manufacturer a number of advantages including; greater flexibility of design, reductions in component costs, more accurate assembly and reliability of seal. Engines designed utilising torque to yield (TTY) head bolts require fewer head bolts to achieve the desired clamping loads than those using conventional bolts. With fewer bolts the engine manufacturer has more flexibility in cylinder head and block design as well as reducing the cost of the engine."
Yeah it's a thing, predating lift arc start. You want to be real good at sharpening tungstens with a scratch start machine as you will be sharpening a lot of them!
I persevered for a couple years or more, but now I've got a decent hf start machine with pedal etc I'd never go back. I found starting the arc with lift tig easy enough, but having to try to speed up as things heated up and then breaking the arc at the end sucked!!
Silverado etc
Briggs aren't really my field of expertise sorry, @ESKIN8R might be more help.
Peel the label off the Duplicolor... /Might be the other way around, but either way Duplicolor and VHT are the same thing, one brand has a stuck on label on the cans, peel it off and it has the other brand printed on the can.
Sounds like breakfast to go at Bort's.
Universal cut to length ones are a fair bit cheaper still too.
Raizer replied to CarolsHusband's topic in Other Projects
You'll need some rubber garden edging and rivets to cover the tread if you go narrow. /I'd probably suck it up and get the 4x4 patch panels and zap them on if it was mine. -
How thoughtful was Toyota to fan force the drivers farts directly at the rear passengers??
Yeah can change to a thicker fluid in them, mine was fucked that even with super heavy fluid it wouldn't lock up. Thankfully it only cost me a head gasket and a gasket set etc rather than the brand new head to figure that out. Brand new one was cheap enough that I shouldn't have bothered trying to mess about changing the oil. Also the 10 blade fan from late model 1KD Hilux is a big upgrade from the stock 7 blade, @GuyWithAviators is the man to talk to about them.
Injector rebuild ASAP. Even with an immaculately clean cooling system a sad injector will easily take out the head, learnt that the hard way.
That's actually a really good question that I'll try figure out tonight/tomorrow after work! I know there's at least some droop, but yeah no idea how much.
That's a smart idea! Current plan is a combo of trying that along with raising the rear 10mm. Them alignment with minimal petrol in and cert with a full tank for the extra weight haha
Ah so that's the minutes he was talking about! There was some confusion when I was talking about bushings or arms that give X° adjustment and he was saying they'd give "probably X minutes" So you're saying raise it up to 4% for cert, then it'll still be compliant with the +/- 5% variance when I drop it back down and fit camber bushings later right? Think 4% is about 13mm at the guard. I was talking to Mike Reid on Tuesday, seemed good to deal with on the phone at least, but he def made it sound like I'd be wasting my time taking it to him if the sheet is even a hair over the .50°, "but Euros have a huge factory allowance so you'll be fine with it slammed" lol
Yeah knew the 0.50° max over stock. Think it's the MIN being a full degree more than MAX on the specifications that's thrown me off. Tyre shop reckoned I needed to get rid of about 2°00' rear, about 0.5° from the fronts/think he was more concerned about the fucked rack end. Edit: been a long day and my brain was stuck in neutral haha Clicked that it's negative numbers so -2 is smaller than -1, looking at it I'm thinking it's within cert specs, I'm allowed -2°50' rear for cert going by that min being -2°00' So I'm all good right? The right rear toe is going to be a case of teaching the alignment guy how to adjust "not adjustable" Merc rear toe/probably have to take my triple square sockets down to do it but should be easy enough. Then 1.25° rear camber bushings and factory option front adjustment bolts can be added later without effecting cert to try save tyres a bit more.
Any issue with either of these for cert? Lol just realised after posting, they appear to be the exact same arms just with different sticker. Went for pre-cert alignment today, if I'm lucky front camber can be brought into line with genuine Merc adjustment bolts and raising the coilovers maybe 10mm. Rear needs something like 2° less negitive camber, caster just squeaked in spec. Oh unrelated but one of the inner tierods is pulling out of the rack so that's fun. Edit: I've been told by a couple people that should be within cert spec for camber, what's your professional thoughts @cletus
I was always told by my old boss and the engine machine shop we used to run plain water only until 50k after re-torque (we mostly worked on old school cars), then coolant. The MLS gaskets I've more recently fitted are a "minimum of 400km" using plain water. -
Keep an eye on SCA for XA welders, they clearanced out all Cig stock a few months ago and I've just seen my local has stocked up with Xcel-Arc accessories, asked and they said they'll have welders etc soon.
Truenotch's 1997 Toyota GranV - Francis Jellybean
Raizer replied to Truenotch's topic in Other Projects
@yetchh 56 ohm 5w and 120 ohm 5w resistors for the 3rd gen Surf temp gauge. Replace the factory resistor on the back of the gauge with the 120 ohm, replace the zenor diode with the 56ohm. Been doing a bit more reading about it, it's not just 1kz vehicles with a factory "dead zone" in the gauge, it's most factory temperature gauges, but after a lot of people complaining/panicking about the needle fluctuating a lot in the earliest 1kz models Toyota went ham on the dampening. -
"Vehicles modified or scratch-built, that have been de-registered (or licensing fees not paid for 12 months or more resulting in the vehicle's registration lapsing), do not need re-certification if they have their LVV certification plate affixed to the vehicle structure. Vehicles with a modification declaration certificate will need to be LVV Certified, as this certificate becomes null and void upon the vehicles registration lapsing. Vehicles that have only original manufacturers' equipment fitted or modifications done that are below the LVV Threshold need only have re-registration inspection and a VIN number issued, if required." https://www.lvvta.org.nz/faq.html
Look up the 1kz temperature gauge resistor mod. Toyota fitted resistors to really slow the temp gauge down in the 1kz powered vehicles, by the time it actually does start to move above half things are real hot!
