Everything posted by Nominal
Rolling the Gal I hope?
Lucas coil or gtfo
Somewhere near the Park Royal I imagine -
Who rotates tyres these days? (I probably should on the Morris as those skinny radials are hard to get/expensive)
Fairly sure the only WOF check on a spare is that it is securely fastened down, or in a separate compartment to the passengers.
Is it stopping it running? Bit of JB Weld over the top?
Probably a crappy aftermarket cap?
Hopefully someone is going? Need to get a WOF for the Mercury this week but will be there for sure.
Toyota, Turbo, 4x4, Duallie. What more could you want? https://barnfinds.com/turbo-dually-camper-1987-toyota-sunrader-4x4/
DIY Removable towbar kit. I think the tongue was from a Hiace or something?. Anyway, a bit of welding, grinding and bolting and it's worked fine for a few years, even with some fair loads.
Because the compressed height of the bags is so much smaller that the coil you may not need cut up the pockets on the chassis - for the Mercury I did all the mods on the lower arms - the chassis spring pockets I left alone, just mounted a big chunk of pipe up there with a threaded rod for the upper bag support.
Yes, it's a dick around trying to find calipers that will work. You could take a walk around a wrecking yard looking for options. I have some sort of Subaru ones on my MM project car that work with the Cortina uprights.
Why not just skim some off the brake caliper adapter bracket to move the caliper back? Seems that it would be easier.
Are you sure one was attached, it seems that a VIN is not necessary if previous registered in NZ? https://www.nzta.govt.nz/vehicles/vehicle-registration/vin/ The one I've had attached to an import by VTNZ is on the inner guard.
I have had a VIN assigned for the woodie so it's properly recorded in LANDATA for the future. I also had the local Repair Certifier come down and take a look before I did anything. He confirmed that it's OK to go ahead and start work replacing the rot myself. He's since passed this project on to the new owner of the shop. so I'll have to get him down for a look sometime soon too. After that I felt it was OK to do a little dismantling. Removed the hood (floppy) and some of the grille bits and the drivers side guard for access to the A-pillar. Also had a go at replicating the front under-floor support. It was hard going in 16g, I made the sides separately using the nibble to fold the bend over as a flange then welding sections into the base. Turned out 'OK' but might end up making it again now I've had a practice run.
- 100 replies
- 35
Nice work. Good for you for keeping at it.
i-car is pretty reputable I think? Here is there read on the Nissan factory instructions for repair https://rts.i-car.com/collision-repair-news/weld-through-primer-guidelines-nissan.html
Tried some of that Recharge liquid and dropping it a bit already. Plates look a bit distorted in that cell and it measure below 12v when taken off the charger. I reckon it's rooted.
I'm charging a car battery with the cover off, and only 5 of the 6 cells are outgassing. I guess the 6th is shorted/rooted?
I think it would be pretty rare to get a cert on a 1st inspection, but you might get lucky. When I took the Mercury in there was a fair list of minor items to attend to. I'm about 1hr north of Wellington and could loan space/tools if you like.
Next month then? -
I think you will struggle to get it registered here without proper paperwork: Proof of ownership You need to provide evidence that you're the legal owner of the vehicle. This can include: the original documents showing the ownership history to the last registered owner in Australia (eg deregistration or change of ownership papers) and an invoice, bill of sale or receipt, etc. https://www.nzta.govt.nz/vehicles/importing-a-vehicle/step-2-evidence/used-vehicles-from-australia/
