Everything posted by Nominal
Continuing on the door pillar, lower section Inner guard area first Then the pillar structure, piece by piece
- 100 replies
- 18
They should just make the auto <-> manual swap a cert item full stop.
Have you considered a 2ZZ?
Getting ready to run the work FB page????
If you do all of that, you are looking at crossmember 80mm of the ground, is that right? Technically you can get certed for less than 100mm ride height, but my understanding is that it's hard/unlikely. Also have to look at what happens if you get a flat tyre, make sure nothing hits the ground. Can you cut up the crossmember and reduce it's size while replacing the strength? /4-link the rear and airbags.
same same same Who'd be a WOF inspector anyway?
So long as you clear these hurdles, there is no mention of a lift limit. But as per the prior discussion, make sure the coils/shocks are a direct replacement. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/steering-and-suspension/steering-and-suspension-systems
So, if they are catalogued as lift springs for a 1998 Impreza, and are fitted to a 1998 Impreza, and all other thresholds are OK, then they should pass WOF?
Same for me now. Google direct links work for a little while, then get broken. @zep it works better if you upload the pics to the forum.
piazzanoob's 1964 ford Galaxie 500 seeedaan
Nominal replied to piazzanoob's topic in Project Discussion
Can I fax you my engine for a rebuild anyway? -
You are doing everything wrong. -
Karol Shusbands 72 Skyline, Betty The Hakopotamus. Discussion.
Nominal replied to CarolsHusband's topic in Project Discussion
The car is better than the house f'sure. -
Not in kiwiland, maybe in wales. -
Lighter is better. Ask Colin Chapman. -
@ajg193?
Hako owner cries poor. Morris badges are cheap eh? https://www.ebay.com/itm/Morris-Minor-Chrome-Side-Bonnet-Badge-MINOR-1000/333580067891 -
Tastes better though I bet.
Best solution is not to let your sheet metal get rusty in the first place @tortron
Was on my watchlist, didn't bid https://www.trademe.co.nz/Browse/Listing.aspx?id=2615322164
Yeah, barely need to look at them. I replaced the Lucas dizzy in my Morris Minor (probably also a 25D) with an electronic Nissan dizzy (N13 maybe?) by swapping the drive gear. Has been pretty well trouble free for 15+ years too.
Have had a pertronix in my V8 since 2004. No issues so far.
- 68 replies
- 17
Good to see the shakeproof washers installed on the d/s loop. Certifiers love finding missing washers
This type? https://www.aliexpress.com/item/32849248540.html I don't need one desperately, just lockdown window shopping.
