eke_zetec_RWD
Everything posted by eke_zetec_RWD
Racing slicks - recommendations and experiences
eke_zetec_RWD replied to eke_zetec_RWD's topic in Tech Talk
Can get the semi in soft med and hard. It seems to be the exact same compound rubber as the full blown slicks. Would love to know for sure. -
Hankook what? model on what car? Cheers -
Basically this will happen - just see what people recommend. 15s is only size i can run. brakes wouldn't allow anything less. avons have a real good range of sizes, has anyone used new avons? -
Looking to purchase some slicks in the near future for my lotus 7 replica. currently running R888's 205-50-15 front and 225-45-15 back on a 8 inch rim. i find them pretty good but thats all i know really. i can find their limits pretty easy. can lap manfield 1.16 no probs on them. im thinking softs because such a light car plus 8 lap races max usually. iv looked at hankook - the semis look to be identical to the slicks apart from two grooves and nearly half the price. avon have a good range of sizes which suit me tyres from the states are sooo cheap ( as is everything else ) but freight is a bit of a killer unless i get lots at once. I dont really want to spend over a grand for a set. what have you tried on what car and how do you rate them? Cheers Jase
I have re drilled my hubs and axles to 4x114.3. You will need to remove axles from the diff. A good machine shop can do this for you. Where are you located?
Sure was, the cosworth yb need it ( and me). Ul see the older non 205 pintos don't have this hole.
Other one is the turbo oil return. It's just goes into the sump.
Umm if there's such a thing then the wire between the key and the starter solinold
Also what was the pressure when tested?
touge's ae101 racecar - ‘fab it all from scratch’ project
eke_zetec_RWD replied to Rhyscar's topic in Other Projects
Advanced anodising on tokaroa. They real good and very fast- 234 replies
Link LEMG1 V3 - 20v 4age ignition timing
eke_zetec_RWD replied to thegreatestben's topic in Tech Talk
Fuck put that in a museum! No dips I can see in pic. Can you rotate dizzi a tooth? -
What kpr said. Il try remember how they work. Something like one down is 4 deg, two is 16 deg or some shit. -
[Fabrication thread] Ideas for towbar modification
eke_zetec_RWD replied to Roman's topic in Tech Talk
Cut both ends off. Weld prep the box with gussets still attached. Bolt side plates to the truck. Offer up the box and center / level it up. Nice little root run will fill the 3mm gap at each end. Capping run to finish. Paint Done. How heavy the truck? Might need a tow connection cert.... Don't cut it in the middle that's rookie as shit. -
Nics Engineering page of 3d Scanning, CNC machining and other junk
eke_zetec_RWD replied to NicT's topic in Other Projects
I made it output peck drilling in straight gcode. It works mint as. More lines of code but runs perfect. If I try run cycle83 it just stops and says option not loaded or some such description. Basically it doesent know what 83 is. It's not a code error as it would say sintax error or ref plane incorrect ect. I Sussed rigid tapping cycle today so hope to get the post updated to work correct for this. I have a few tapping jobs in the morning that will have to be hand written dam it. I havnt crashed it to any great extent yet but I can see how it happens with all these dodgy post processors around! It would fuck shit up! Pretty much no stopping it it's sooo powerful. -
Hyundai v800 with a Siemens 810d and a mmc103. Cycle83 - hasn't seemed to have loaded the cycle file on startup. It's deff still in its correct place ect and it's on the start up load list. It can read line by line g01 and g00 no probs but my post won't output this for it's drilling. That is a option for fixing it though! -
I wouldn't say a lot at the moment. I'm having a few issues with post processors and my machine not running peck drilling cycles. Hopfully my tech man will get it Sussed tomorrow. I'm very new to cnc but i know manual machining and solidworks well -
Maby, bobcam is very labour intensive. For short runs and custom parts like what I do it's too slow in the cam stage. It also doesent auto update tool paths if you change the model at all. That's the whole point of having integrated software in solidworks. -
Bring tomorrow so I can have a look -
Ohh who's used solidcam in solidworks? Is it the bizz? -
Shane from supercheap a? -
Any luck? Has anyone used bobcam 4 axis for solidworks with out smashing the computer screen? -
I'm not aware of much yet, only got it running on Monday. It's not in German but it basically assumes you already know the controller inside out when it tells you to change something. -
German is a bit beyond me too. And so is the manual lol. It says what menu to be in to change the parameter but not how to get to the menu. -
Any one a pro on the seimians 840d controller? I need to unplug the 4th axis but to do that I need to tell the controller to not look for it. Bit beyond me! -
Brennan's, ke70 Corolla, 3sge Beams powered.
eke_zetec_RWD replied to Brennan's topic in Project Discussion
No it's not actually dead head. Just did a test like that to check the pumps max pressure and to rule out the reg as a fault
