durty
Everything posted by durty
  1. Knock out back of garage and dig ramp in dirt behind garage and take it through there? Take to the top of the bank above the property and roll it down?
  2. Magnets?
  3. Lower it more to get rid of guard gap then put smaller tyres on again to stop guard rub? Then lower it more to get rid of guard gap then put smaller tyres on again to stop guard rub? repeat till touching ground?
  4. put it up on end then tilt it down under power lines. Kinda like moving a sofa into a house?
  5. http://www.ebay.com/itm/NRG-12mm-1-2-Steering-Wheel-Spacer-Hub-Adapter-Kit-Black-momo-to-Nardi-Personal-/231131987353
  6. Chur, I need so many parts to lush it up a bit and also some bits to sort out slam so that is super helpful
  7. That place sounds amazing
  8. Definitely vents
  9. http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-686260662.htm ??
  10. Next time you do rego can just write new colour on the form I'm pretty sure
  11. Will get mild slam after wof is obtained. Then more slam once I have collected parts needed. Have a plan for what I'm going to do already
  12. More pics. have done about 1000 miles or so since getting the car and absolutely loving it, Towed trailers for a bunch of people and helped a couple of people move Also got new overlays for the speedo etc Before After They are inspired by the r-sport gauge clusters that were an optional extra, easier to read during the day and amazingly easier to read at night when lit up Also latest issue to arise is this: car off car running Need to look into this, will swap alternator from my 360 and see if that sorts it, guessing the voltage regulator in the alternator is screwed (I hope)
  13. I have some pics. Will chuck them up tomorrow at some point.
  14. Either of you cunts want to be picked up and dropped off after? That way no driving for yous
  15. Temp sensor should screw into the thermostat housing from memory.
  16. Shouldn't be too hard to find. Most 940 and 960s should have one as well as turbo 700 series. I found one at pick a part but car was gone when I went back to grab it. That ected looks awesome That mod pretty much makes them into a locker that can still freewheel one wheel when turning at low speeds. And will also one wheel every now and again. Which is not as good as a proper locker but works out way cheaper if you can get one easily. Can check of they have one by scraping the underseal off the passenger side axle and white sticker should say 1041 on it
  17. Did you ever organise getting an LSD or Locker for the volvo diff? If not and you want a cheap locker could always get a g80 out of a volvo 940. They are a bit shitty stock as they will only lock when one wheel spins faster than the other and then disengage if speed gets above about 60kph. But the volvo guys do this mod http://www.turbobricks.com/mods.php?content=art0027 where you cut most of the weight off so it will stay engaged and locked well above 150kph. From the sounds they pretty much act open when driving slow but if you start spinning one wheel they start acting like a normal welded diff
  18. I have never had much luck getting parts off them for some reason. They have had the parts I needed and just never got round to removing them for me. Will give them a try soon. Need to focus money on Xmas for now. Also know a guy who had a bunch in a shed but lost his details so will try dig those up Also would rather pay "dude wrecking one in garage" prices instead of actual wrecker prices
  19. pffft, LS1 wouldnt happen for years unless I won lotto. Working on slam at the moment. Just collecting parts for it. Really need to find someone wrecking one so I can get a spare pair of struts Will get a little bit of low in the next few weeks then will get full slam hopefully before nats
  20. and for front lights or or And I can't find any pics of cars that have the all orange option
