Dudley
Everything posted by Dudley
  1. The actual worst, typa guy to run a megasquirt or something aye
  2. The owner of that car is a dickhead though….
  3. Doesn’t yungblud need bezels from a highroof @GARDRB
  4. A real crown enthusiast would slap a Holden 6 in it
  5. The colour isn’t loading
  6. Mate there is something wrong with your recent photos
  7. If I get fries per car, then technically I could drive down get fries, drive home change car go get more fries and repeat till I run out of old cars?
  8. What’s the limit on old car to fries ratio?
  9. Nah burgerfuel is too spenny for me, unless @GARDRB shout?
  10. I have a spare 4k you could use I guess
  11. Does your car even require a cert seeing as your loosing power going from the mighty 5k to a 4age?
  12. Dude I like to mix a bit of red and black silicon so I can rep Hikurangi
  13. Guide coat primer like the rotary gods always intended
  14. I’ve heard the 5k head has a better short turn radius in the port then any 4age head except maybe the famous 12,300rpm formula Atlantic head in the orange cars, what are your thoughts on this @kpr?
  15. If the gear can’t handle me it’s a fail m8
  16. I’ve had xcel arc and boc and if im Buying another welder it will be another xcel arc
  17. I have a pair of right and left Midwest snips and they have been amazing and worth the $$$ for body saw I got Astro one and it’s been really good for the price https://nz.jbtools.com/astro-pneumatic-930-air-saber-saw-with-5-piece-blade-set/?srsltid=AfmBOorQThGbXP_hPLiNHxAwO1h61wIjzr4WkWIJVlGeBuHOOMiYAmN0 yeah 90degree die grinder are the go to tool for grinding back the welds and not thinning the metal around the weld
  18. He kept telling me all day how incredible the experience to work on a 20v was , only issue was the itbs are too big for the 4age and in that setup It will never rev to 12,300 rpm
  19. Nah love the xcel arc, I only use it for mig and it zings panel steel up to 5mm plate lovely. also it’s 10amp plug so that makes life easier
  20. I really rate my xcel arc mig for panel steel, I used to have a boc 180 mig but it had a really long post flow you couldn’t adjust so it chew through gas when just zapping tacks on panel steel, I think post flow on the xcel arc is 1 sec and the boc was around 5 secs, doesn’t seem like much but the more gas you save the better https://www.xcelarc.nz/product/viper-185-mig-tig-stick-welder/
  21. You go work on your van aswell
