Everything posted by JustHarry
Sounds like a bit of a have Usually trailer brakes are just sorta like yeah they arnt dragging and they stop a free wheeling wheel so the do something Good to go
When it rains my feet get wet There is also a cold breez from under the dash whilst driving I thought u would investigate. So i pulled the dash out found some yucky Then this happend Then this happend Not ideal But a pretty good result considering its a 70s toyota. Will be a straight forward repair
- 38 replies
- 18
Can stay with me for a bit if its only a week or two. Can keep my l300 company If the seller can deliver to chch makes it easy
Did this this morning at work. Centre bearing was noisy and loose. Hilux centre with the crown housing bolted around it. Sorted Much quieter
- 38 replies
How long till you could come get it?
Justharrys still a farmer. Now has a mitsi truck
JustHarry replied to JustHarry's topic in Projects and Build Ups
This has been a bit of a sack. Blew a heater hose cos the coolant system was pressuring because the headgast was leaking. Then because of the blown hose i think the headgasket went properly and it started gushing collant out the radiator cap So today i replaced the headgasket. Was also lazy and didnt do the stem seals. Meh. Front brakes are also real grabby. Fuckin drum brakes Put some moreys in the motor to stop some of the smoke.... Also fitted a tach so i can see it doing 5000rpm at 100k Winning combo- 8 replies
- 16
This thread is an abortion. Needs a clean up. Since half the pics dont work Anyways. This got a wof last week. Then i cut 1.5 coils out. Needs more tbh Also fitted some 205/70/14 to the factory steelies One day i might paint it. But not today
- 38 replies
- 18
I ask this in fear of being ridiculed But whats the legality of something like this. This one exactly?
Likey my crown.
@Mof ? @DoBro Jesus ? Maybe of use
Do i see this on trademe? @Nominal
EpochNZ's Teenage Wet Dream Sierra Estate
JustHarry replied to EpochNZ's topic in Projects and Build Ups
After much to long it now has color where ive done repairs Didnt take a pic after clearing it. Looks the sane but shinyer- 10 replies
Sold the 720 Regretted it Wanted a bigger deck Bought a 1980 l300 truck 1600 4 speed with drum brakes all round Has a bit of rust as all good Mitsubishi's do More to come- 8 replies
- 20
All going well i should have a new addition to the fleet to showcase on sunday
Been fighting the transmission for a while. Still slipping badly in first and revs spiking into second. Checked the transmission ecu. All visually looks ok. Good enough for me. So today i took at the pan off and removed the valve body to check solenoid operation. They all seem ok. I also dropped the valave body out of a e33 galant thats donated many parts already and unsurprisingly the valve body is almost identical. One solenoid needs to be swapped over then will go in. With any luck it woll solve the issue as it came from a fully functional transmission Og on the left and the galant one on the right
Touched up around the a pillar and front guard this eveing Will put the drivers door back on and do the doors and back guards at the same time- 10 replies
Justharry's smokey Mitsubishi V2000 noisy tappet busted auto sharn
JustHarry replied to fuel's topic in Project Discussion
The issue is finding another one. A guy i work with cut his teeth doing autos. He recons hes got a book that should have some stuff on measureing line pressure. Im thinking maybe a soldniod is packed up? Im not sure if it would matter but i think the trans cooler in the radiator is blocked from when it got repaird. As one of the cooler lines was dry. Ive since looped the cooler lines and it made little difference -
I did locate it today. Its a mare to get out of rhe v2000 I also took the debonairs one out. Turns out one of the plugs is different. Fml I guess I'll have to try something else -
Mr.mk1's Mopar or No Car '70 Dodge Coronet
JustHarry replied to RUNAMUCK's topic in Project Discussion
I imagine you will be able to buy almost every part you need to repair for this? That will make the job 11ty billion times quicker and easier. Especially with large and involved repairs Talking from experience in the matter -
I recon sunday mornings
Ok. Ill have a better look today. I suspect it is a computer fault just because when i manually select 1st it drives fine -
I have a debonair here i can swap it out of 6g72 and auto I had the centre consol out yesterday and i didnt find a tcu. Only a power steer controller and the ac/heater computer behind that -
So do i -
Yes im sure about that
