Everything posted by JustHarry
- 38 replies
Got the patch in welded and seam sealed up. Shouldn't leak water into the cabin now. Most of it is covered so just flicked a bit of black on it for now
- 38 replies
- 16
- 38 replies
Also a strategic dent in the dump pipe will make little to no difference to the engine
The ceramic tips the guns usually come with are pretty shit and the hole opens up pretty quick with use. When this happens the venturie effect is reduced and it doesnt pick much sand up. There is two options. Replace the tip regularly when it wears. Which most people do Or there is a company in chch that specializes is sandblasters and sells some fancy tips that cost like 250$ and last "forever" (we go one for the bast cabinet at work like 3 years ago. We were replacing them every couple days and since havnt replaced the fandagle flash one. Cant rememebr where we got it from but can find out) Work has a machineryhouse one thats pretty decent otherwise.
I have the number for getting tools replaced on my toolbox as i suffer the same ussue of no truck anymore. Will get it for you minday
Mr.mk1's Mopar or No Car '70 Dodge Coronet
JustHarry replied to RUNAMUCK's topic in Project Discussion
Mig welding a bonnet like that is a sure fire way to fuck it. Also rust converters are a have. The correct way to deal with the frame being rusty like yours is to get it sandblasted. Its inexpensive and does the job properly. -
Whats it weigh? Wouldn't be very heavvy. If its an issue just put an unbraked coupling on it?
I know right
Still on the look out for a 3.36 holden diff for this. Ht/hk/hg Should be corse spline but will pull an axle and check
Sounds like a bit of a have Usually trailer brakes are just sorta like yeah they arnt dragging and they stop a free wheeling wheel so the do something Good to go
When it rains my feet get wet There is also a cold breez from under the dash whilst driving I thought u would investigate. So i pulled the dash out found some yucky Then this happend Then this happend Not ideal But a pretty good result considering its a 70s toyota. Will be a straight forward repair
- 38 replies
- 18
Can stay with me for a bit if its only a week or two. Can keep my l300 company If the seller can deliver to chch makes it easy
Did this this morning at work. Centre bearing was noisy and loose. Hilux centre with the crown housing bolted around it. Sorted Much quieter
- 38 replies
How long till you could come get it?
Justharrys still a farmer. Now has a mitsi truck
JustHarry replied to JustHarry's topic in Projects and Build Ups
This has been a bit of a sack. Blew a heater hose cos the coolant system was pressuring because the headgast was leaking. Then because of the blown hose i think the headgasket went properly and it started gushing collant out the radiator cap So today i replaced the headgasket. Was also lazy and didnt do the stem seals. Meh. Front brakes are also real grabby. Fuckin drum brakes Put some moreys in the motor to stop some of the smoke.... Also fitted a tach so i can see it doing 5000rpm at 100k Winning combo- 8 replies
- 16
This thread is an abortion. Needs a clean up. Since half the pics dont work Anyways. This got a wof last week. Then i cut 1.5 coils out. Needs more tbh Also fitted some 205/70/14 to the factory steelies One day i might paint it. But not today
- 38 replies
- 18
I ask this in fear of being ridiculed But whats the legality of something like this. This one exactly?
Likey my crown.
@Mof ? @DoBro Jesus ? Maybe of use
