igor
Content Count
12,980 -
Everything posted by igor
SU carbs are brilliant because they are so simple. In 36 years of BMC ownership the only issue I've had with them is the piston getting stuck either fully or partly down resulting in not starting in the former case and only running slowly in the latter. Loving the way this project just keeps developing by the way.
I had the misfortune to drive a colleague's automatic Bighorn from somewhere north of Bulls to Tauranga one night. It was a truly horrid car. The automatic kept changing gears at inappropriate times. Being raised a bit on huge mud tyres probably didn't help in that respect.
So in the pursuit of lower emissions we are making engines use more fuel than they really should? Seems counterproductive.
Do you have a logical explanation for that?
Finally got the pedal box out of the parts car today. Got the column out last weekend with some most appreciated help and advice from @smokin'joe. We ended up leaving the linkages to the trans all connected and removing the shaft from the shift lever up by the steering wheel. One bolt. Like many things it became obvious with another pair of eyes looking at it. I'm getting my wof guy to do the swap into the good car cos it was super cunty getting it out and I broke some stuff. @kiwiplymouth, I've been there with those horrible pins. The first time I took the motor and gearbox out of a rod
Are paper gaskets alone providing an insufficient seal?
This was standard starting practice for our MF135 back in the day. Any random piece of steel to bypass the shagged starter solenoid. Used my sheath knife once cos I had nothing else handy and blew a big gap out of the edge. Not thinking very hard that day.
Anyone? There must be a relatively simple way to take these things apart surely.
igor replied to johnnyfive's topic in Upper North Island Region
Sure does. That's like 177 mpg. I used to get 115 mpg (2.5ish l/100 km) out of a CG125 and thought that was pretty good. I'd love to be able to participate in events like this. Have to get my fun by reading the stories of others' exploits unfortunately. -
igor replied to TimShadboltfan27's topic in South Island Region
It is exactly this that dampens my enthusiasm also. Much as I would love to meet up with you all my budget does not permit it.- 1,055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
A while ago now I broke the pedal box in my manual EA coon. My wof guy welded it up to get me mobile but he reckons it will break again. He also reckons automatic pedal boxes are the same and that they just have a longer rod to hold the extra pedal. Today I started removing the column from the automatic parts car I have here in order to be able to remove the pedal box. Everything came undone easily except for the column change linkages. I can't see how to disconnect the linkage anywhere between the column and the trans without cutting or breaking something. There must be a way to do this. What
How far South are you coming? I've been following this for a while and I'd love to see it.
You didn't go over Finlayson Road from Waihola and up the coast road to get to Dane's place did you? That road's questionable even with a small trailer.
Is that cos modern lead free shit?
Agnetha, love it.
So it's like a structural magnesium supplement?
Sweet tractor. Does it start on petrol then you switch over to kero after it warms up? When was the last time you saw a kero pump on a servo forecourt?
Bollocks.- 1,055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Work Hilux had an error like that cos some genius had put 15" wheels on it. At an indicated 150 on the speedo the terratrip said 133. Never fixed it, everyone knew it was dodgy and drove accordingly.
If they were a factory option it might have factory mounting holes? According to the brochure my Wolseley should but I haven't found them yet.
True. Better to just whack five motorcycle carbs on the thing right?
Five cylinder triple carb should be sweet if the one in the middle that fed one cylinder was half the size/flow of the other two shouldn't it? Would look weird as hell.
Women's sleeping bags are a thing? -
Long as it's not Dolcett.
