Everything posted by Mof
- 340 replies
Run big cable directly to starter, then smaller cable to fuse box/alt etc
I've always just done my bumpers in black zinc. If it gets scratched off by scrub or tree branches just touch it up. Can't touch up powder coat. And unless you zinc or galv under the pc if it gets a scratch through the water gets under and it rusts and lifts off.
Right thread? Axle stands, rating per stand or per pair? Seems hard to find this info, most manufacturers seem to dodge the question
Any bearings poking through the front of the housing? Do you need the thickness of a gasket for bearing preload?
Mof replied to yoeddynz's topic in Other Projects
Have they got a residual pressure valve in the drum rear master cylinder? -
Yes, sometimes I remember about it. I'm almost never over your side of town
@JustHarry was there a gauze under the valve?
I had a hilux in a few weeks back that stopped and wouldn't start again. The fuel gauge had stopped working and was stuck on half, but the tank was empty. Had just enough in the tank to make it seem like it had fuel when you prime it with a hose off
Let me know if ecu is no good, I think I have a backup
https://hiluxsurf.co.uk/forum/hilux-surf-forums-technical/-3-0-turbo-diesel/86611-1kz-te-starting-problem End of page 1, start of page 2. Just a quick Google guess. ^that's spill valve relay. Maybe also check the condition of the capacitors in the ecu, make sure none have leaked out onto the board. Ecu is under the dash behind the glove box box. According to that link relay is in there too for a surf, probably the same.
MOLESWORTH MOPED MELEE, 4th, 5th, 6th March 2022
Mof replied to RUNAMUCK's topic in South Island Region
Workmates doing similar dec/Jan with an xl125. I'll borrow/ buy it off him. Also depends if I am able physically
