Everything posted by Mof
Electrolysis - brass plug should fix that. Cavitation - a cavity behind the plug creating air bubbles, is the plug in deep enough? Coolant mix (but I doubt it) - no more than 50/50 mix, 30-40% antifreeze is best. Too much af to water can be acidic.
Got a pic of the old one?
#6 should be coming off exhaust and onto intake (rocking) when #1 is at tdc fyi
Will find out
Is there supposed to be a copper washer under the head of the screw?
Driveline down here just took a turbo td42 from the workshop in bits. It dropped #4 liner, but depending on yours you might make 1 out of 2. I don't know what their plans are for it but they might be happy to move it along. Dream build btw, love it
Are wider offset rims covered by cert? Thanks
Hello gents Is there a way to reduce the power steering assistance? I feel it's just too light. Cheers
You said oil pump, do you possibly mean fuel pump? As the oil pump would be in the sump
@spanners
@h4nd I could. I think I just dodged going to ashvegas. @NickJ will you be attending?
I believe the resister wire is pink, or pink/white trace
Btw a work lamp is not a cosmetic lamp Cosmetic lamp means any lamp that is not listed in Table 4-15-1. Table 4-15-1. Lamps that are not cosmetic lamps Lamps covered in the VIRM Other lighting equipment not requiring inspection Headlamps Stop lamps High-mounted stop lamps Direction indicator lamps Position lamps (includes side-marker lamps and end-outline marker lamps) Rear-registration-plate illumination lamps Rear reflectors Fog lamps Daytime running lamps Cornering lamps Reversing lamps PSV interior lamps Work lamps Interior lamps Designed to illuminate the interior of the vehicle for the convenience of passengers Flashing or revolving beacons Illuminated vehicle-mounted signs Includes PSV destination signs, taxi signs and variable message signs operated by enforcement officers, under a traffic management plan or permitted by other legislation A light source that is a necessary part of equipment required or permitted by any enactment to be fitted to a vehicle Includes LEDs that indicate status on eRUC labels
Apparently two spot lights or two light bars are ok on high beam as they are symmetrical...
Stand alone switch, not on high beam. And not aimed to front distance like a high beam, (work lamp for lighting area around vehicle) Tilt it down at wof time
Don't suppose your engine man was in chch? No long drawer up the middle of the deck from the rear?
I think I remember terrano rear diff being the same as safari front diff, lsd in terrano rear...
^I tried one of those in the Samurai (lockright), it was shit, undriveable. Constantly unlocking either axle at random. U-turns were impossible, driving a straight line was impossible tbh. Even the diff shop couldn't get it to work. (There's a bit of a story here, but spam). Don't imo
Got room for east/west? Transplant the whole engine, transaxle, subframe, suspension
Op = troll, seen him post lately? Must have had nothing better to do on a Saturday night
Troll
Ho shit that's a dodgy workshop Have you thought about getting advice from free law type thing?
Are hondas front/rear or diagonally split? I had this on a Curren, but rears
