Everything posted by locost_bryan
Can you use the "reuse of plates" option? https://www.nzta.govt.nz/vehicles/licensing-rego/number-plates/ (scroll down to "Re-issuing number plates") ... although that would be re-registering the car.
Personally I think the square shape of the Hunter would suit Mk2 Escort flares.
Browndog's 1978 Ford Transit Sundowner #3
locost_bryan replied to browndog's topic in Project Discussion
Ah, is that why you're selling your other Sundowner? -
Pity they automated the lighthouses, the keepers were always portrayed detailing their ships in bottles while the storms raged outside (before they ruined it all by rushing outside to rescue some damsel in distress ). Back in the 70s I built a lot of kits, before I started playing with full size cars. With my two brothers, we built a '40 Ford Coupe with a rumble seat (from a kit called Flower Power), and a custom Model T truck, as well as a dune buggy and a Chevy Nomad and a 57 Impala, and a '60s dragster station wagon (a Plymouth iirc). Also built a Ford F150, an AMC Gremlin, and a whole lot of sports cars including a Mazda RX7 and Porsche and Ligier Le Mans racers. Built a White Road Boss with a fuel tanker (iirc), and a GMC (Actros?) cabover with a furniture trailer. The only scratchbuild I ever did was when I was at high school, converted a Mk2 Capri into an OSCA race car (sort of a non-spaceframe PDL Mustang 2 clone), with handmade box flares and a rollcage made from pieces of the plastic parts frames, and the V8 from an AMT custom Ford Econoline van. I made a trailer from more offcuts of the parts frames, and spare wheels from other kits. The V6 from the Capri went in the Econoline, that would have made a terrible real-life tow wagon. Must ask my mum what happened to them after I left home and she moved house. Probably got some photos buried in a box in the spare room.
@CarolsHusband I'm jealous of your abilities with models. Haven't made any since my teens, and nothing like you're doing. Great to see your work, keep up the postings, loving it.
You'll have to get @yoeddynz to post on your behalf.
Marina TC gauge cluster on TradeMe, no reserve $50, buy now $150 https://www.trademe.co.nz/a/motors/car-parts-accessories/performance/gauges/listing/3055463673?member_hash=1d3fe7ffa8fab2c642e5b46b74bedf6a9753acb48b6185f72d&tm=email&et=46&mt=E4472408-8060-4EB7-90BB-725D852E5CEF&bof=5Hzhjn59
locost_bryan replied to Roman's topic in Tech Talk
Race car paint has "orange peel" finish for the same reason, supposed to improve flow by disturbing the layer of air that "clings" to the surface. Some discussion here http://speed.academy/10-myths-of-cylinder-head-porting/ https://forums.mightycarmods.com/forum/technical/tech-talk/798217-porting-clearing-the-elephant-in-the-room-about-rough-vs-smooth-vs-dimples -
Cool, forgot that later Maxis would have got the "metric" HIF44. Great find for @kws, he should be able to whip up his own extractors to go with it.
Looks like you've got the holy grail, twin 1.75" carbs on E-series manifold. Are there any numbers on the carbs? E-series has 4 ports, B-series has 2 ports.
Is that a result of better thermal efficiency , or just the extra power allowing a lighter right foot?
No, I think the detailed production records were lost when the Zetland factory closed. Hard to work out from chassis numbers, as each variant was numbered from 1001, so yours is the 572nd Deluxe 1750 manual Coupe. Production was about 200 cars per week, roughly 40% were Deluxe, and 40% Coupes, but I don't know the % for engine and trans. You could probably use a spreadsheet to make a guesstimate. Because your chassis number doesn't start with a "Y", it's probably NZ assembled. If you have the original rego number, you will be able to find out the date first registered, the build date would probably be only a few weeks before that. Honda have some NZMC records, but I don't think it includes any Marina info. Could be worth asking on FMM forum, or on one of the Aussie Leyland facebook groups.
I certainly never paid anything like that for freight from the US for similar size packages.
If you get desperate for a rev counter. US$80 (approx NZ$115) + $157 shipping https://www.ebay.com/itm/RVI2435-01A-13H6796-Smiths-Tachometer-Austin-Marina/163646571445?epid=6027593855&hash=item261a1883b5:g:N90AAOSwZKlcLqOJ
No speed info getting to the computer. Read a bit about it here https://www.2carpros.com/questions/wont-shift-out-of-1st-gear-please-help
Both. Lucas changed from inductive (RVI) to single wire (RVC) in the early 70s, and it appears the Marina started with RVI then changed to RVC. The wiring harness should have the bullet connectors for a RVI, or a wire with a spade connector for the RVC. A GENTLEMAN’S GUIDE TO SMITHS ELECTRONIC TACHOMETERS Wiring a Marina Tachometer
Nice job on the gauges. If you don't have any luck finding a tachometer, I have a spare.
Locost Bryan's 1972 Morris Marina TC Coupe
locost_bryan replied to locost_bryan's topic in Projects and Build Ups
After delivering the filter elements just before Christmas, discovered the base plates were missing, and had to order those too. So another months delay, but what the heck, it's been a while already. Delivered the base plates, and the engine guys were finally able to run the engine safely, without worrying it would suck in a lose bolt or some such. Due to the time it had been there, they had been having to move it around a bit, which wasn't doing the engine any favours, so was recommended to run it under load on the dyno to bed in the rings. Getting it to run properly turned into a bit of a drama, when carbs were set correctly at idle it ran very rich higher up the rev range. The temporary solution was to wind the jets down to lean out the mixture. The permanent solution will be new jets and needles. Might get some leaner BBR needles from the Maxi HL, to compare to the Marina's BAD. Finally got it home today. Nice to hear it running, and to reverse it off the tow truck and drive it into the garage. Clutch working well, no trouble engaging first or reverse. A couple of things will need attention, lots of travel in the brake pedal, despite the calipers being overhauled, no doubt the rear cylinders will need looking at. Rev counter not working, supposed to be ok with the Powerspark distributor, will need to check the wiring. Pulled out the back seat, which is a brown cloth one from a later car, since I want to keep the original vinyl seats for authenticity, and the matching cloth front seats have completely different mounts anyway. Underneath I found two of the quarterlight rubber hinge blocks that I'd spent a year scouting the world for, and had finally found in a paddock near Invercargill. Wonder where the other two ended up. Anyhow, here are a couple of videos of the engine running. OCD will require turning the filter mesh and clips to line up properly.- 10 replies
Rust in the guards is usually where mud collects, behind the headlights or by the A-pillar. Looks like it might have had ding and not been well repaired?
Dual filament bulb holders in the rear indicators because 70s Aussie cars used them for reversing lights. Select reverse and both rear amber lights illuminate. Can remember dad's XA Falcon doing the same thing.
My first Marina rusted out the bottom of the spare wheel well, might pay to check the drain hose that goes through it is still connected. I haven't seen a "Hinged Kerb Guard" with the flat flap extension, maybe they added that later. Mine only had the oval part. This is the correct top radiator hose on eBay Australia, and the correct bottom radiator hose . The prop centre bearing is supposed to be the same as the Triumph Dolomite, available from Rimmer Bros or off eBay UK. The Marina club do some replacement panels (reproduced from original panels), but it doesn't look like you've got any repairs that you can't handle yourself https://www.morrismarina.org.uk/marina-a-ital-remanufactured-panels/
Rover did an injected version in the '80s (although the S-series had the ports on the right as it was installed the opposite way round to the Maxi) https://www.aronline.co.uk/cars/rover/rover-213-216/vitesse-story/
