Tumeke
Posts posted by Tumeke
  1. I finally finished my wiring loom last night. All the lights I have work (aliexpress hurry up cunse) horn works, and wires don't get hot when I turn the key. Seems I mastered wrangling pixies so far, although will need to check for charging etc.
    Nek is fuel (carb-spin and tank plumbing) then i can kick 'er in the guts and do hunnits on the stand cause still waiting for the rear sprocket to come from the internet land.
    Also remembered I need to fabricate foot pegs and probably quite a few other chobs.
    • Like 6
  2. I'm no metal gluer but what I have learnt is:
    1. What the fullas above are saying.
    2. I use argo-shield gas,  .6 wire (smallest I could find) and follow the instructions on the box.
    3. After cleaning with a wire wheel,  I often rag with brake-clean to get rid of any oil/ grease crap too. (This is mostly due to British car, where even the panel gaps leak oil.)
    Also - take up peoples help offers. I would / will etc.
  3. Having owned one I suggest:
    1. lift the battery out and check that it hasn't rusted through directly above the fuse box. (water/rust/pixies are a bad mix)
    2. Don't break the rear window. (Get new struts if they have lost gas)
    3. If it has dog leg 1st like mine did, remember this at the lights.
    4. Don't lust after a 924.
    5. Skids are expensive with the rear trans-axle setup if anything pops.
    Otherwise have fun. Pretty much a VW van engine so pretty reliable. Early fuel injection isn't worth touching unless you have someone who knows how to work on them. I had the turbo version which was quite happy to swap ends in the rain  - notably on the Khyber Pass on-ramp which proved to be quite entertaining.
    • Like 6
    • Thanks 1
  4. 11 hours ago, cletus said:
    See that chev truck at least once a week all around auckland. He must do a heap of miles in it
    Pretty sure that's the one that goes lives at one of the Pukekohe Market gardens. Has a couple of loads (sometimes with trailer) to Auckland 'errday.
