smokin'joe replied to Roman's topic in Tech Talk
has a query. re-mounting tidying up my concrete mixer, current motor 1/4Hp 1425rpm, non-cap.start....... will not run on 1000w continuous invertor if i replace this motor with 1/2Hp twin cap start....... will the capacitors allow the invertor to run it ? -
was there a decent turn out for this event ? went for a quick squizz at the Muster in G-Town, had a decent display for a new event... 200-ish car they reckon, but only the Ford Cortina Club had a decent club dislplay
cock, have to be down this week, but the fella not available for weekend pick-ups. a couple of lads on the list would to catch up with, and few i doubt i have met
coil-over should be located on top of diff and into upper spring perch. the very parts designed to take the vehicle load -
TGP were, by far, the cheapest for son's Surf, but ex-Japan. eventhough it is a LN106 with wagon body, BNT/Repco/local brake shop had none in local stock either -
ensuring it is not a wheelbearing issue, first
i made a heap of 12vDc heating pads to go under propagation trays, and fitted a basic ' variable resistor' type controller as getting too hot and frying the seedlings. i have a nuggetty 12v coil heater here if you wanted to see if that will work. 12v heating wire wrapped around steel/copper core, incased in concrete inside 100mm PVC. yours if you want it
what about a urethane or PVC jointing cement like plumbers use ? -
Clint, is it true, that anything that needs re-vin/re-rego from either June/July this year, needs full chassis/underside strip/sandblast to check for rust ?
but Mr, it is non-turbz 3L choocha mobile
so if the lad fits new sparkbungs to his LN130 manual Surf/4Runner, will is fix the excess smoke and give him more than 15WHP ??
GN's are the current Suzuki farm bike. low seat height works well for smaller built dairy farmers, and knobblies added for grip. we sell them as a new bike
at this rate, i may have replaced the LC80 by 2024 !!
terrible idea, love it !!
but don't you use waste oil as chain-bar lube ? -
i didn't realise you had even plotted the route when i first posted about 'key' access. as for setting one up, am not a rider, and with limited L/H function, nor would i endeavour to attempt something of this, as it would need to be ridden prior. i could advise some loops, if wanted/warranted, for a quite compact event. @RUNAMUCK Middlemarch Mainiototo !!
WOW, good coverage, looks like a name change to Midland Madness......... the 'key' comment was to keep it in McKenzie/SCanty, but awesome trails. i do have a more compact 'local to Farlie' route involving keys, if needed
Maruia Moped Melee, 10, 11, 12, March, 2023
smokin'joe replied to RUNAMUCK's topic in South Island Region
better than mo-ped, which implies moustached pedos !! -
i was meaning the route, Baaaart. a couple of keys from landowners will add to the epicness -
is it the full 'kit and kaboodle' or the gentlemans scoot ? -
ok, or the 'stretch' the outside radius, opposed to 'shrink' the inner -
could be as simple as forming non-braided hose, whereby one 'scorches' the inside radius around a hot former........ same way coiled air-hoses are formed, and coiled shaver cords are done. thin-wall metal tube and a grunty electric paint stripper gun -
another stout option is A-series forkilft motor.... think they A13/15..... ?
don't they use linear actuators to raise / lower ?
there was a trap for event organiser's as to how the road was closed. one method gave TOTAL control to the named COC/Safety Officer etc, the other created headaches as to legalities legalities and control , if a challenge was enacted
