AllTorque
Moderators
Everything posted by AllTorque
  1. You are not allowed rust within 150mm of that bonnet catch, so removing structure in that zone will be a no no for WOF.
  2. https://www.trademe.co.nz/toys-models/die-casts/dinky/auction-1718060266.htm
  3. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/exhaust/exhaust-system see line 5 as long as it cannot enter the passenger compartment, you are fine
  4. Silly Billy @Seedy Al I’ll let The Boss know tomorrow.
  5. I think you should measure inside the rollers with the internal side of the calipers. Like so
  6. I guess this isn’t going well enough yet to know, but what’s the top speed of this monster?
  7. Could be a bad earth at the headlight? Earthing through the brake bulb causes the headlight to brighten?
  8. Don’t get me started on dirty tissues in the door pull.
  9. @Vertigo I have moved your question here, to the wof and cert thread.
  10. This is rad. How big is it? Would I fit on it? If so, giz.
  11. Boy, this is fancy. Don’t forget about drive shaft hoops. You will need them for a cert.
  12. It falls into the category of anything the inspector seems to be unsafe. It cannot be a fail just because it leaks. There used to be something about oil leaking onto the exhaust but that was removed. You might get an old boy that will fail that if they haven’t read the virm lately. If there is a lot of oil on the exhaust Iwould fail it. I have seen an oil on exhaust fire before.
  13. Oil leaks. As long as it’s not going to cause a fire or get on the brakes it shouldn’t fail a wof.
