SOHC
Everything posted by SOHC
  1. Hello, Would someone in auckland be able to help me do 4 flares on 2 coppernickel brake lines, they are off the car and I can bring them to you, and I might be able to get my rat rod on the road.
  2. SOHC
    Welding VS brazing
    Every thing will be cool then, you could use the legs off an old chair
  3. SOHC
    Welding VS brazing
    I don't think you would get a cet if your frame is half welded and brazed, its only bikes that were produced from fractory with brazed frames that will pass. 1.6mm Chromoly, or 3.2mm mild steel for cert.
  4. SOHC
    Welding VS brazing
    At my old work we built alot of motorcycle frames, they were always brazed, the frames with cast lugs that we repaired were silver soldered (easyflow) its strong as hell, I easyflowed the hex nuts on to my cylinder head through bolts on my BSA, they haven't failed yet. you do need to make sure the parts are very clean. I use oxyacetylene I have an old acetylene producer, only have to fill my oxy cylinder
  5. Dose anyone have a link to ruels or have any info about roll cages? Someone I know has 2 cars he wants to put on the road but I don't think it can be done with out major problems as they have home made full roll cages.
  6. Is it running sweet now? I have had annoying problems with my red brick, turns out the near new dizzy rotor had a capacitor in the top, the spark was jumping over it. Dose your cylinder head have holes for injectors?
  7. SOHC
    Misfire at idle
    Dizzy rotor has a resistor in the top, I think that was bad, replaced the rotor and now its running sweet, missfire seems to have gone.
  8. SOHC
    Misfire at idle
    I should do that next but I don't have a tester, I wiped the cam cover off and a quick check with the engine warm they all have clearnce. feel like paying someone elce to sort it out, I have wasted about 4 days on this allready.
  9. SOHC
    Misfire at idle
    I hope not, I must check the tappits, might have a tight one? they are bucket and shims, yay.
  10. SOHC
    Misfire at idle
    I replaced the gasket, it runns better but misfire is still there, plugs look like it was / is running lean, will check timing like madmitsy says, I have allways just twisted the dizzy round till I find the spot it runns the best
  11. Could you drill the bolt head conners and use lock wire?
  12. SOHC
    Misfire at idle
    found that the intake manafold gasket was leeking a bit, I hope this will be the cause of all my trobbles
  13. You could get a metal spinner to make you some nice pancake air filters and use the elements from a Triumph or something.
  14. SOHC
    Misfire at idle
    I have a 1981 Volvo 245 GLE with Kjet fuel injection witch has developed a intermittent misfire at idle and seems to do it a bit when you pull away from the lights, it seems to run very well otherwise, has good power. and is good on gas I have replaced plugs, HT leads, dizzy cap, injector O rings, tried a different IGN coil, Plugs look like it has been running lean, I don't have any way to check the fuel pressure, but I have enough spare parts to replace most of the K jet system. the air control valve seemed to have a hole in the top by that small nut is that ok? I smoked some tea leaves and blew the smoke in the vacume advance tube and it was comming out that hole witch looks like it shouldn't be there. What elce should I check? any good DIY tips? Here is how it works http://www.k-jet.org/articles/information/k-jet-in-detail/
  15. Are you going to fix that rust? or is it doomed?
  16. There is a guy in south auckland, its around $35, I would have to look up his contact details, look up def pom raido mods on google I think he dose it to
  17. You should check your SWR or get some one to check it, Ya shooting skip is a bit of fun, the guys in hawaii are funny as hell
  18. Is it on the 26mhz? You could probley shoot some skip with that big antenna, I have been talking to western australia latley
  19. Did you get that raido-CB working in the end?
  20. SOHC
    Thermostats
    Yip it was air lock, let it cool right down and the level in the expansion tank went down, toped it up and its away.
  21. SOHC
    Thermostats
    I will have another go tonight and report back, I can squeeze the hoses and get most of the air out on this car
  22. SOHC
    Thermostats
    I have had this problem a few times before after draining the cooling system and leaving it for a day or so with out any water, when I fill it up and run the motor the thermostat won't open anymore and is stuck shut. but put a new thermostat in and its sweet. Just put a new thermostat in the volvo but had to redo the water pump seal and now the bottom radiator hose gets hot as hell and the top one is cold. I have got all the air out. temp gauge shows its getting hot and it over flows from the cap. Any tricks to fix this problem?
  23. is the mic and PPT actually in side the shaver case?
  24. Why dose it have a shaver on the mic cord?
  25. Are they copper-lead bearings?
