Everything posted by SOHC
I have been fitting them them to everything from motorcycles to lawn mowers, they do one called a Super Coby that has a chamber in the front that sounds super nice on an old 6 cylinder, I had some of them on a v8 with duels and it was nice, I have one on my 4 cylinder Volvo
This whole thread should be renamed where to weld the Coby in
Not super horrible, a new big end and mains should see the bottom end done, I may reuse that old piston. People reckon I should press the cams off the shafts and swap them over but then the ramps are on the other sides of the lobes. Gearbox is apart and I need a new 2nd M/S gear, I found a new 1st, I got given most of a clutch and a kick start leaver
Both the big 4 engines have ball race bearings from factory, they can stay that way. When the waka taniwha had its 2nd blow up the maines needed to be replaced and they were over $600
I found another WD Big 4 engine, it has the tappits and valve lifter I was missing, also the cam pinion is better than the one I have. Much to my surprise and glee this engine doesn't have lipped roller main bearings, they are about $400 a bearing, this just has ball race bearings.
SOHC replied to sr2's topic in Project Discussion
Could you not put the expansion tank any higher? -
SOHC replied to h4nd's topic in Other Projects
- 1289 replies
- 31
Can HPC do a white exhaust coating?
Its funny BMWs only make max power with the stock liuftmaster mufflers, can do any mods to the engine like supercharge etc but every exhaust system under the sun wont preform as well as the stock system lol. Wile you can slip the gearbox back and lube the clutch splines and check the flywheel bolts. Thats the only photo I have with my BMW
Got a honda GX200 and a torque converter to fit, it had a China 110cc CT style engine when I got it but it wasn't mounted very well
Got this old gokart, frame was cracked in about 6 places on that one tube and had meany layers of 1/4" plate brazed on, had to use the plasma cutter to blow out all the layers of steel.
This oil is good for old ironheads, your engine wont wet sump as bad and spew out every little place it can and your front cylinder will love you.
- 1289 replies
- 33
Its for a 1937 dodge, 1st year of hydraulic brakes, it needs some help, thing is too fast for its own good.
Would you need a cert for a RPV or hold off valve to?
Would a remote brake booster need a cert?
- 1289 replies
I have found those cheap die grinders are more air hungry than better ones, I have a bluepoint one that uses half the air of a cheap China one
They make them from a softer alloy and they are like a anode so you dont fuck the head
I rember you had to set the adjustment so when the 3 balls run up the ramps the cabel arm stops at 90 degrees
