Steelies Posted August 21, 2012 Share Posted August 21, 2012 yeah. are you using that same speed of sound in air value as your speed in exhaust gas? anyone know the worth of lagging the spanny to keep temp and speed up? Quote Link to comment Share on other sites More sharing options...
KIRK Posted August 21, 2012 Share Posted August 21, 2012 i think the answer for low max rpm + single gear is megaphone. mainly cos they look cool Quote Link to comment Share on other sites More sharing options...
Steelies Posted August 21, 2012 Share Posted August 21, 2012 build it Quote Link to comment Share on other sites More sharing options...
KIRK Posted August 21, 2012 Share Posted August 21, 2012 i already did but when i tried to weld it onto the flange i made it melted and i got angry and smashed it with a hammer. right now my bike makess too much power for the driveline and handling so no point anyway lol Quote Link to comment Share on other sites More sharing options...
Testament Posted September 3, 2012 Author Share Posted September 3, 2012 I think another blood sacrifice may be required to get it running again the way this saga is going..... Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 3, 2012 Share Posted September 3, 2012 and i didnt even put any ballbearings in that one Quote Link to comment Share on other sites More sharing options...
Rookie Posted September 3, 2012 Share Posted September 3, 2012 The spark has escaped again... But it did fire and run for approx 5 seconds! Quote Link to comment Share on other sites More sharing options...
Testament Posted September 5, 2012 Author Share Posted September 5, 2012 after alot of this I tried a little bit of this and it resulted in this ALuyuOgGJuo Praise be satan? (or mostly a coil swap and brakleen ya bastard) Quote Link to comment Share on other sites More sharing options...
Testament Posted November 11, 2012 Author Share Posted November 11, 2012 Please donate 24" tyres and tubes, it's for a good cause Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 11, 2012 Share Posted November 11, 2012 the spannys worked out well? Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 11, 2012 Share Posted November 11, 2012 Yea, it picked up a bunch of low down torque, pretty mean. Needs more carb fettling to get the most of it though. Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 11, 2012 Share Posted November 11, 2012 is that where you wanted power? you gonna keep it at that length? Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 11, 2012 Share Posted November 11, 2012 TBH it needs more handling now, not power, but I seem to recall it didn't do what Tom thought, but probably turned out better. Quote Link to comment Share on other sites More sharing options...
KIRK Posted November 11, 2012 Share Posted November 11, 2012 maybe lean it off was pretty lots of white smokes when I was following it Quote Link to comment Share on other sites More sharing options...
Testament Posted November 11, 2012 Author Share Posted November 11, 2012 nah it was pretty close to what I thought, just need to recheck the calcs for actual motor rpm to see if it was even getting into the "powerband" - the tuning was for about 5500-5750 rpm, I got the diffuser taper too steep though so thats probably not helping (will narrow the powerband of the spanny) and the baffle cone is shallow taper/15 deg which reduces max power but extends the powerband past the peak power (but I dont know if the engine speed is even getting there though. but on sunday morning initially with a small jet (1.2mm) and the spanny it was pulling real good down low, we put the jet back up to the old size with straight pipe/megaphone (1.8mm) and it wouldnt idle and was real flat. I'm guessing without the spanny most of the fuel was going straight out the exhaust so it needed heaps just to still have some in the motor. soldered that up and drilled to 1.6 for the race but I think I can still lean it out a bit more. looking at a few other tuning options too - but I think I might tear it down 1st as it seemed like it may have chewed a rod bearing or something a bit when we put it on the trailer a the end of yesterday - in the excitement of the race I forgot to top up the magic oil reservoir when refuelling which may have something to do with it...... edit: yeah what ^ he said needs to lean up a bit Quote Link to comment Share on other sites More sharing options...
KIRK Posted November 11, 2012 Share Posted November 11, 2012 maybe wack a little peanut butter jar lid and wifes sock airfilter on it like my bike or experiment with intake length. a bit longer will make it more peaky. I need to shorten mine as made no power down low but screamed up top but gear ratio to tall so couldn't get into the power on track edit: I would chop your intake and add some rubber hose in. engine vibrations shaking carb will froth fuel in bowl and make it rich Quote Link to comment Share on other sites More sharing options...
Testament Posted November 11, 2012 Author Share Posted November 11, 2012 just did some quick calculations, was only pulling about 4000-4500rpm at 70-80 odd km/hr so it's not even coming onto the pipe properly as it is. hose intake is a good idea for tuning may look into this further. and really need to get a 60mm pulley Quote Link to comment Share on other sites More sharing options...
Testament Posted November 23, 2012 Author Share Posted November 23, 2012 rode around the corner and noticed this when I got to dave and jess's place. There was only one thing for it. And that kiddies, is how you make chewing gum! Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 26, 2012 Share Posted November 26, 2012 Jeah, burnouts on Well done haha Quote Link to comment Share on other sites More sharing options...
