Popular Post rdaum Posted October 8, 2024 Popular Post Posted October 8, 2024 Recently I was lucky enough to purchase this fine machine which has a little family history. It was the first car built by GT40 Replication Ltd in Auckland. One of my grandads mates was the man behind GT40 Replication and so my grandad did some of the mold work for these cars. I told my self 16 years ago when I heard about this car (when I first got interested in proper cars) that if it ever came on the market I would buy it. 15 years later luckily enough it came on the market and I was kind of in a position to buy it (you may have seen all my shit for sale here and trademe). Anyway, here we are and its in my shed. Its an interesting concoction which i'll discuss once I actually start working on it, but I plan to just drive it and enjoy it over summer. It needs quite a lot of maintenance, but the bones are good. Has Rover V8, Renault Transaxle, DBA/Holden fronts brakes, seems to go pretty good. Have found lots loose on the induction side and it looks like the cap,rotor leads and plugs are the same from when it was built so I will do them all shortly. Air filter was coozed, has a Holley 600 on it unsure on jets etc yet but it drives nice, slight flat spot if you punch the pedal down but I havent fault found it yet. It needs a gasket kit but that will likely be next winters job... 32 5 Quote
Alfashark Posted October 8, 2024 Posted October 8, 2024 Were you driving it over the hill towards Ararimu on Saturday? Quote
rdaum Posted October 8, 2024 Author Posted October 8, 2024 Me or a buddy, had a couple of friends have a go since buying it. 2 Quote
440bbm Posted October 8, 2024 Posted October 8, 2024 Nice! that 600 is probs a bit too much carb for the lil rover. common problem with 600 on the rovers. the 390 or 450 work much better but are pretty rare to find. in saying that you have maanged to find a very rare car as it is so maybe you have that ability.. anyway, maybe it is well cammed and high comp and a well modified card to suit so i could be talking shit. but looks choice! 1 Quote
rdaum Posted October 8, 2024 Author Posted October 8, 2024 6 minutes ago, 440bbm said: Nice! that 600 is probs a bit too much carb for the lil rover. common problem with 600 on the rovers. the 390 or 450 work much better but are pretty rare to find. in saying that you have maanged to find a very rare car as it is so maybe you have that ability.. anyway, maybe it is well cammed and high comp and a well modified card to suit so i could be talking shit. but looks choice! Funnily enough I have an edelbrock 450 I am investigating. It had a 390 early on according to the documents that came with it but it wasn't doing justice, perhaps the tuner was the problem though. I'll definitely be looking in to a more suitable carb. They seem to work together well enough for now, I'm going to catch up with the builder soon and hopefully find out what the engine is exactly. Which of course I'll report on here... 5 2 Quote
440bbm Posted October 8, 2024 Posted October 8, 2024 awesome! it's got a bit of fruit in it then! 2 Quote
rdaum Posted October 11, 2024 Author Posted October 11, 2024 The dirty bitch has bitten already, melted a wire, only off the kill switch, only in the middle of papakura.. mate came and helped push it off the road in to a carpark and wedged a piece of my work lanyard in to hold the wire in to get me home.. 8 1 2 Quote
rdaum Posted November 15, 2024 Author Posted November 15, 2024 Leaky sump gasket so went to investigate while the pan was off. Largely ok from my not too invasive look around. Sump baffle bolt snapped while undoing which was cool so easy outing blew out the time frame. Hopefully reduce the oil slick. The numpties had been running it on castrol 0-30... cant imagine that's done it much good. 6 Quote
440bbm Posted November 15, 2024 Posted November 15, 2024 well the good news is the cam lobes looks pretty good and now you also know its running a flat tappet setup. stock looking rods ( but hard to really know ) and its been sleeved by the looks and the bores look like they're pretty fresh still. in terms of the oil, prob best to run it on something bit thicker with a decent zinc additive or that penrite with high ZDDP additive. but pay to find out a little more why that grade, there could be a reason but cannot think of a decent one. while the pants are off, whip a couple of the caps of the main and big ends to see what the state of bearings are like with such thin oil. if they're fine then you can put some better lube in it and she can do another turn! 1 Quote
rdaum Posted November 15, 2024 Author Posted November 15, 2024 Yea I was relieved to see the state internally. There will be no good reason for the oil except that's what his mechanic had in stock. Last owner was not a gear head and the mechanic was a modern car person sadly. Have a few bottles of the Penrose vintage zinc stuff in the shed so she'll be getting some of that. At this stage I'm not sure I want to know any more about the state of the bearings..... Quote
440bbm Posted November 15, 2024 Posted November 15, 2024 Gotcha. LOL i hear you.. but it is a prime time to just put new ones in if they have warn the coating off. generally all possible to do without removing the crank, can just slip them in.. like before you have to go through the pain of removing the sump again and getting another gasket etc etc. 3 Quote
rdaum Posted November 15, 2024 Author Posted November 15, 2024 For sure, If I cant get the leaks sorted in situ then itll be coming out over winter anyway, may be traded for a windsor if that's the case. Need to talk to a certifier as I suspect they would want to see a cert on it, despite probably miniscule power gains. How do you driveshaft loop a transaxle... 1 Quote
rusty360 Posted November 15, 2024 Posted November 15, 2024 Sounds and looks like a epic car!, I might be wrong but you should move it into the project thread. 1 Quote
kws Posted November 15, 2024 Posted November 15, 2024 If it still has a standard steel sump pan, check the flange on it is flat before refitting. People always nip the bolts up too tight to try to fix a leak, and end up warping the flange around the bolts and it'll never stop leaking until thats fixed 7 Quote
rdaum Posted August 18, 2025 Author Posted August 18, 2025 Small updates here and there. Painted light buckets black as there was far too much white. Replaced horrendous big orange lamps for proper prince of darkness units. Had a niggly brake issue where it felt like one would drag every now and again. Interesting to fault find with no disc's looking hot or anything, double remote booster etc. Anywho had 5 minutes so gained access to the master cylinder boots, suspect problem located. 3 new Tilton masters on the way (clutch is the same cylinder), no chance I ever want to remove those again. Now on to the rest of the brakes, hopefully before the driving season kicks in.. 9 Quote
Willdat? Posted August 18, 2025 Posted August 18, 2025 Saw this for sale last year, I think it went for US$9,000,000. 1966 Pine Green Ford GT40 Mk1 Street For Sale in Florida — Supercar Nostalgia https://share.google/GRdpO1VRIzmpg19Vh 1 Quote
rdaum Posted August 18, 2025 Author Posted August 18, 2025 8 hours ago, Corbie said: DRAG DAY PLEASE /caps That would be laughable with the current engine Quote
CUL8R Posted August 19, 2025 Posted August 19, 2025 Not sure how I missed this, sounds very similar story to one I had some wheels made for. Customer got it from a Hanger down south, where it had languished for 10-15+ years. SBF, Renault Transaxle (open wheel non lsd) - he has a Turbo Axle he will swap into it. I think that particular car had some mechanical problem, a "mechanic" got hold of it with great intentions but no follow through until this guy got it. If I remember it was something like 5000km use in 25 years. HQ Front brakes - He's dealt with Les Hunter for a Wilwood Caliper & Rotor upgrade. I guess because of the Renault Trans-Axle is the reason it was running 5/112 all around. Was quite a tame SBF, think stock 70's 302 with smog manifolds & low compression, thats been pulled for a crate motor He had a full big list of what parts from what donor cars were used in the various areas of the car You can guess his theme; 3 Quote
