Tachos and speedos are screwed down, but I am not sure how to remove the faces of these fuel and temp gauges. Does anyone have any clues? Should I try and tap out what looks to be a pin? I'm a bit worried about breaking them.
What are they out of?  Looks to me like the pin holds it all together and is punched/flared during assembly.  You might be able to drill out the end of the pin, but them I'm not sure how you'd put it back together?
They are from my Gemini. If I have to drill out the end of the pin, that's not the end of the world. I could always reassemble with a screw and nut. You don't see the pin heads when it is assembled anyway.
if the pin is hollow, I have heard of people threading them internally and using a screw screwed into the pin to reassemble (not on gauges, but something else I can't recall). I agree with Bryan that it looks like a pin that has the end flared out holding it together
The Marina gang coming in hot!
I don't think it's hollow. It has a few mms of internal space at the end but probably not enough to thread. I'll put one in the drill press later and see if it wants to pop out.
